New YM1700 has questions
   / New YM1700 has questions #11
Bob,
I am not sure what 70/30 water/coolant mixture will protect your tractor DOWN to, but you might want to make sure that your night time temps don't exceed. Being in Mobile, I doubt they will, but just check. Our night time temps are still down in the 20's here in NC. Just my two cents.
Newton
   / New YM1700 has questions #12
Here in Kansas I run 10w40 rotella 9 months out of the year. I use rotella 30w July to September.....Also don't let your engine freeze.......I could not use 30/70 mixture here....but my 2210 has a water pump..
   / New YM1700 has questions #13
Sailor bob.. I use 15w40 in all my diesels.. no problems.
Also.. the others bring up a good point. You may have to slightly adjust your af mix if you do have low low temps. Course this should also offset some heating problems if you are running the tractor in sub-zero weather /forums/images/graemlins/shocked.gif
Soundguy
Soundguy,
That is good news about the oil. As for the freezing issue we don't have too much of the really cold weather here and spring has already sprung here.
If you don't mind one more question about cooling what causes the coolant to circulate without a water pump? I have ran the tractor pretty hard for up to 2 hours at a time with the brush cutter attachment. I seem to wear out log before the tractor gets tired. It is amazing to me how powerful this little tractor is. It just grinds up the brush like it is nothing.
Thanks to everyone that responded.
   / New YM1700 has questions #15
Cooling systems without a water pump rely on the difference in density between hot and cold water to create circulation by natural convection. Just like air, as water gets hot it becomes less dense and will rise. So inside the engine's water jacket, the coolant is heated and tries to rise, being replaced with cooler water from the bottom of the radiator. The hot water moves into the top of the radiator and is cooled there, becoming more dense and tending to sink to the bottom of the radiator. This is called the "thermosypon" effect.
Higher concentrations of anti-freeze impede the ability of the coolant to circulate. I live in western MD where temperatures drop down to the single digits in the winter, and I still use only 25% antifreeze, 75% distilled water in my YM1110D which doesn't have a water pump. I have gone through 3 winters without freezing the block. If I were you, I would use the 25% anti-freeze/75% distilled water solution and not worry about freezing. It is also important that the cooling system be very clean.
You should start by using a cooling system flush product to flush all the gunk out of the radiator and block. Use a hose to back-flush the radiator and the engine block. You might want to remove the radiator and take it to a radiator shop for cleaning and pressure testing. Then fill with the 25/75 mixture. You should have no overheating problems after all this.
That was a great explanation and it makes sense to me. I will try your suggestions. My coolant looks awfully rich so I suspect that it probably part of my problem.
I will post another message letting anyone interested know the final outcome. I have been reading back through the forum and notice that many never report the resolution of their issues.
   / New YM1700 has questions #17
Greg,
Maybe I need to get another "antifreeze checker". During the warmer months; I drain the system, flush the system, and replace with the same mixture. I checked it last year before the cold nights set in, but the "checker" I have said it would only protect to the mid to upper 30's, so I drained some of the fluid out and put more antifreeze in. My 1700 is in the barn but it is not heated and I was more worried about cracking a block. Do you check yours before winter? If you did check; what was it good for with the 25/75 mix?
   / New YM1700 has questions #18
</font><font color="blue" class="small">( but the "checker" I have said it would only protect to the mid to upper 30's )</font>
/forums/images/graemlins/grin.gif Mid 30's isn't even freezing... nor would upper 30's.
If you had a 25% mix of AF.. it should lower your freezing temp lower than 32'. etc
Soundguy
   / New YM1700 has questions #19
"Do you check yours before winter? If you did check; what was it good for with the 25/75 mix?"
According to the chart on the Discount Autoparts antifreeze jug a 25/75 mix protects to +10 degrees.
   / New YM1700 has questions #20
Soundguy,
I figured it would too, but..... There have been plenty of nights in the 10's and 20's and didn't want to take a chance. I will get a new "checker" before next winter.
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2014 Aerway Aerator (A55973)
2014 Aerway...
2022 John Deere R4023 (A60462)
2022 John Deere...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
