newbie...is a TC30 enough
   / newbie...is a TC30 enough #11
Had my TC 30 about 2 years now. Does everything I want it to and more. As said before take it easy and let the machine do the work, don't force it and you'll have years a seat time without any additional expense. Good Luck on your choice.
   / newbie...is a TC30 enough #12
   / newbie...is a TC30 enough #13
Offroadr, I did a good deal of research before I purchased my TC30. It is a great little tractor. For the money and quality, it is hard to beat. I've used mine to mow 15 acres, did fine. It tilled three acres with a 5 foot tiller this spring. Following the tilling, it pulled planter and cultivator over two acres several times now. I had ag tires put on her and she is one hard working little girl. However, I wanted small because I trailer over 100 miles each way. The TC30 4wd is probably close to 2400 lbs. That is on the light side for a tractor. So, is this the tractor for clearing several acres of your 10 acre place, maybe not. Now, I love mine, and have enjoyed every minute on it. But I work slow, slow and steady. There are some heavy tractors that are economical and a good value in my opinion that might do better at dragging around big logs. Take a look at the Farmtrac 535 or 545. This is similar to my old Ford 2000, small, heavy, and tough as nails. Also, take a look at Mahindra. They have one that is heavy and priced right, also quality. These are 2wd I mentioned, but the extra weight will take care of that. They also have them in 4wd for extra $$$. But then a little extra $ opens up some of the heavy 4wd cuts, Branson, Mahindra ...
Take a good look at them all before you decide.
Would I choose my TC30 again. Yes, I sure would. However, would I have picked it if I did not have a need to trailer my machine and I wanted to clear several acres of trees and brush, NO.
   / newbie...is a TC30 enough #14
   / newbie...is a TC30 enough #15
I have a JD 4120 (engine HP about 28, PTO HP about 22). I purchased a Woods 72" finish mower and use it to mow about 3 flat (no hills) acres. Looking back, I should have either purchased a smaller mower, or a larger tractor. When the grass is either tall or at all damp (for example, in the spring), I have to go pretty slow to keep the JD from laboring. As a result, I'm thinking of buying a bigger machine (New Holland), which is why I have been lurking on this site for a bit. My research tells me that more HP is relatively cheap (I've found that, in general, an additional 5 HP costs from about $1,000 to $1,500). My advice would be to go up a notch in HP. I don't think you will regret it.
I hope this helps.
   / newbie...is a TC30 enough #16
I hope this helps.
   / newbie...is a TC30 enough #17
Off, I took care on 161 acres for 14 years with a 25hp tractor, so start with the tc30. It should be fine for quite a while.
   / newbie...is a TC30 enough #18
   / newbie...is a TC30 enough #19
I have just over 300 trouble free hours on a 2003 TC-30, 4wd, gear, 7308 fel, loaded R4's. She has done everything I've asked including dragging down timber home for bucking and splitting. grading hard clay and top soil with a 5' box blade, a 6' back blade, and the fel, dragging a disc, running a 5' tiller, and brush mowing anything I chose not to cut with the saw.
I have never stalled it, but losing traction has limited me on some of these jobs grading job. She will sit there and spin if I take to heavy a cut with the box blade or if I'm trying to push or pull to much material with the fel. I believe it's weight is about 3600lb total, 1995lb tractor, 1000lb fel, and 600lb loaded rear R4 tires.
   / newbie...is a TC30 enough #20
JOHN DEERE 560M LOT NUMBER 138 (A53084)
JOHN DEERE 560M...
Tailgate For Pickup Truck (A53117)
Tailgate For...
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
LOT NUMBER 160 (A53084)
LOT NUMBER 160...
2019 Chevrolet Tahoe SUV (A51694)
2019 Chevrolet...
