Newbie spends quality time on OLD tractor.(long)
   / Newbie spends quality time on OLD tractor.(long) #31
I also am found of solid, tried and true technology.
The 8spd trans in my 1975 ford 5000 is virtually identical to the 8spd in my 2002 7610s. Good solid basic trannies.. one of fords best, in my opinion... perhaps a bit limeted in reverse and top end speed.. but overall.. not bad.
As for the difference in using an oldie vs a newbie.. I guess it depends on the machines.... Pretty much -0- difference mowing on my 5000 vs my 7610s.. even though 32 ys seperates them. In the dark.. hard to tell them apart too.. biggest difference is about 25 or so hp... not much else..
Soundguy
morningwood said:
George,
Not wanting to start a old tractor vs new tractor debate but I guess my point is that you can buy alot more old tractor than you can new tractor for the same amount of money. Yes, they do not come with a warranty and yes they will break down more often since they are old but they are going to be cheaper to repair and in my case they are paid for. :D
It sounds like you appreciate what we have now, which is great. Personally I will keep with my 3 speed crash box. ;) Even though I am sure any hydro machine or syncro machine depending on the chore could work circles around me but at the end of the day but I know that the crash box will probably be working at the end of the day.
If you are ever passing through central Ohio stop buy and you are more than welcome to give the old Fordson a work out.
Scott
P.S. Dman, I agree with you. Plus the collectors market is also making them kind of pricey.
   / Newbie spends quality time on OLD tractor.(long) #32
I'd say by the mid 60's independent pto could be called 'commonly' available anyway.
At least a few manufacturers went to some kind of hitch help on the cat 2 tractors. Ford for instance had a flex hitch that let the ends telescope out and wobble to make hookup easier. Some JD did as well.
Soundguy
N80 said:
Thinking about that old Case, it was really ahead of its time in a couple of ways.
First, the Case-O-Matic transmission. I really don't understand the details of it or how it is supposed to be beneficial, but, it was ahead of its time and is apparently fairly durable.
Second, independant PTO. Was this common on tractors from the early 60's? I personally like an independant PTO and it works exactly the same way as the one on my 2005 Kubota. I don't know if it is implemented the same way mechanically.
Third, it has a built in quick hitch on the lower lift arms. I'll try to get a picture sometime but it is quite ingenious. The end of the lift arm is like a hook with a little pintel the locks the hitch pins in place. This does not look like an addition, it looks like it came on the tractor. I think the lower lift arms are telescoping as well (or used to be). Both of the lift arm links are adjustable.
In any case (no pun intended) it looks like Case spent a lot of time thinking about the deisgn of this machine.
I also liked the cast iron rear wheel centers that act as wheel and weight.
   / Newbie spends quality time on OLD tractor.(long) #33
That jeep appears to be millitary, but definately not WWII vintage. The WWII units did not have tailgates, just a spare tire mount and fuel can holder on the back. I can't really see the windsheild well in that picture but it appears to be a single piece of glass. If so, I'd identify it as an early '50s Korean War vintage M38. The civilian version would be called a CJ3A. If it had the earlier split windsheild it would be a CJ2A. Many of the parts for jeeps of that vintage will interchange with each other so it could be a mix of several models. I used to collect old jeeps, here is a picture of a 1947 CJ2A I restored back when I was in High School. Right-Front.jpg
As it happens I know a bit about old Case tractors as well. The Case-o-matic system basically consisted of an automatic transmission style torque converter mounted in front of a standard stick transmission. It had a lever which engaged a clutch to bypass (lock up) the torque converter. These units got a bad rap back in the day because many farmers didn't know how to operate them properly. The idea was that under normal opearating conditions you would run with the clutch engaged to bypass the conveter. If you ran into a tough spot that lugged the tractor down, you would disengage the bypass clutch and allow the torque multiplication of the converter to pull you through rather than having to stop and shift to a lower gear. As soon as the tough spot was passed, you were supossed to engage the bypass again. Farmers would run into trouble with the units when they ran for extended periods with the bypass clutch disengaged. The torque converter would overheat if worked too hard for too long. It is not unusual to see the paint burnt right off the bell housing on Case-o-matic tractors from this heat.
   / Newbie spends quality time on OLD tractor.(long) #34
That is an Eagle Hitch, and was available on Case tractors from the late 40's through the early 60's. The Case-O-Matic transmissions became available around '56. The 830 was available from 1960 to 1969 or 1970, the one in the picture is an early 60's model from the looks of it and it having the eagle hitch. By the mid 60's the 830 had a Cat 2 3 point.
The 830 came with the rounded rear fenders, or if you had the Comfort King version it had a sqaured off rear fender. They also made an 830 Western with big fenders that covered much of the tire tread.
   / Newbie spends quality time on OLD tractor.(long) #35
Afternoon MJB,
Beautiful restore on that old Willys' !!! Thanks for posting that pic !
   / Newbie spends quality time on OLD tractor.(long) #36
MJB, that is one cool looking jeep. Do you still have it?
   / Newbie spends quality time on OLD tractor.(long) #37
I sold the jeep about 6 years ago. Something had to go to make room for my JD 4300.
Maybe not. I don't know much about them. He's the expert (just got back from some big military vehicle show out in Arkansas.) In any case, his primary interest is the WWII jeeps and from what he tells me, that is what most of the bodies, etc he has stored all over the place in old pole barns are.
Excellent info! That is exactly how my B-I-L told me to work it.
He pretty much told me to get the thing rolling and then engage the bypass clutch. If I hit a deep spot I'd disenage it just long enought to get through and then engage it again. Very strange system. I've never asked him why he has three of them. I suspect his Dad probably bought them new. I'll ask next time I'm down there.
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
New/Unused Mini Skid Steer Attachment Set A (A57454)
New/Unused Mini...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
20ft Shipping Container (A57453)
20ft Shipping...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
