NEWBIE
   / NEWBIE #11
"How do I remove concrete splatter of paint on a tractor?"
Try little diesel on clean rag but don't rub to hard,for there might be cement grit.
   / NEWBIE
Marble is made from compressed minerals and capable of taking a high polish. It comes in many colors depending upon the minerals it is composed of. Marble today is used for floors and countertops and is usually laid in tiles that come in many sizes. :)
   / NEWBIE #13
I would try wd40 soak it an dont try to rub it for a few days.Whatever is in wd works to clean alot of stuff.
Army Grunt
   / NEWBIE #15
Thanks for info. :)
   / NEWBIE
Why are the rear tires of a tractor bigger than the front tires?
   / NEWBIE #17
Have you tried spraying on some WD40 and letting it sit overnight? Try a test area and see if it works for you . welcome to TBN:)
   / NEWBIE #18
It's a matter of steering geometry. Imagine how much room you would need between the inside of the tire and frame if you were to use large tires in the front. That is why the big 4wheel drive machines are articulated. Good to see some ladies posting.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Yale Forklift (A56435)
2013 Yale Forklift...
2018 Toro Workman MDX Utility Cart (A56857)
2018 Toro Workman...
BUSH HOG 8 SHREDDER (A58214)
BUSH HOG 8...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
13 Ft Ball hitch Trailer (A56859)
13 Ft Ball hitch...
