Newby intro and YM2000 question
   / Newby intro and YM2000 question
Well a little update. Since most posts didn't indicate it to be a common problem and the radiator needed repaired anyway ( wouldn't hold pressure is an understatement, both the front and rear seam on the upper tank blew and the tank bulged outward) I removed it and inspected it as I repaired it. Although the guard in front of the radiator was clean, the fins in the radiator were easily 2/3 or more full of mud/fine grass and who knows what else. It took easily 30 minutes to completely clear them. After clearing the fins, and straightening a few, I repaired the tank and re-soldered it and pressure tested it..held fine. I now believe what happened was that the radiator couldn't dissipate enough heat while I was mowing for the extended period and the coolant got hotter and hotter, eventually turning to steam. The steam was releasing into the recovery tank with such force it kept blowing the top loose. After a certain point the steam couldn't release fast enough through the overflow tube as the heat built up and created enough pressure to blow the seams apart. It's repaired now and the paint is drying, I'll install it tomorrow and give it a test, but am pretty sure that was the problem. I'll post tomorrow with the results. Thanks for all the input, I was afraid that head gasket failure was a common issue...much like some of the V6 Ford engines.
Now.. what about the front wheels??
   / Newby intro and YM2000 question #12
Sure sounds like you got the problem taken care of.
   / Newby intro and YM2000 question #13
If your tractor is 4WD you will need to keep the same size front tire. Lots of discussions about this. Welcome to TBN. We have a Superformance dealer close by us in NC.
   / Newby intro and YM2000 question #14
Good to hear that hopefully you have solved your problem. Make sure that your anti-freeze/water ratio is correct. A mixture ratio of anti-freeze must not exceed 40% to aviod overheating.
I would flush your radiatior several times to insure that it is really clean.
Dick Jermyn
A final update, and another thanks for the input. After repairing the radiator, as I was prepping the coolant recovery for re-attachment, I noticed that the passage had melted shut from all the steam that was being produced. I drilled the hole clear again, re-installed the radiator and coolant and did a test run to check for any leaks...it was good. I then took it out and finished mowing the back acreage and it worked great with no indication of a heating problem. After running it shut down fine and a check of both the coolant and oil showed all was apparently fine. So... with all the debris in the radiator cooling fins it was creating a bunch of steam and after a while it caused the passages in the overflow cap to close up and then the pressure built up enough to POP the radiator at the header seam..I still can't believe that the pressure didn't blow the hose off the radiator to the recovery tank first, but it didn't. All seems to be great again, I will be keeping and eye on it as I start working it again.
The Olthoffs, great bunch of guys, I have talked with Dennis several times and gave some assistance a couple years ago when he broke an axle running at IRP during the One Lap of America. They couldn't be too far away since their address is also Mt.Ulla.....it couldn't be spread out that far :)
   / Newby intro and YM2000 question #16
Mt. Ulla is one of those places that would not have a post office if politicians would step aside. (a very good place to live though) Dennis and family go to church where we do. His place is about 2 miles from me. The cars are test driven by my house and I like it!
   / Newby intro and YM2000 question #17
Oh, I know where that is, I have a friend that lives in Statesville...........
   / Newby intro and YM2000 question #18
My office is in Statesville.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56436)
2016 Chevy...
