Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
We are having a friendly conversation is that ok with you?
Didn't know my permission was needed to carry on this friendly conversation, but for purposes of keeping it 'friendly' by all means carry on. Permission granted.
It may be plenty friendly, for the most part but not very constructive. I've seen everything under the sun thrown out as possible causes, from cracked blocks to bad caps, radiators, water pumps, head gaskets, hoses, foreign objects, etc.
Logic would dictate to those who actually work on engines that bubbles in the overflow tank are MOST likely related to exhaust gases escaping from an improperly sealed head to block and caused by the gasket between them not doing it's job for any number of reasons. The fact that anti-sieze was used would lead me again toward what was done last- assembly of head to block and torquing of head bolts. Thus, checking actual torque tightness of the bolts after running the engine a few times through it's paces would reveal exactly what was revealed- loose bolts. Tighten bolts and run her again. Problem solved- case closed. Little wild-a$@ed guessing and a lot of time and energy saved.
As far as anti-seize, it's great stuff and I use it all the time. It may be specked for use on Navy vessels which are in a particularly corrosive environment all the time but most tractors aren't subjected to constant salt air and such, and therefore preclude the need for such extra measures. And as Dirtdonkey said torque specs could be reduced with it's use - which in this particular situation led directly to the problem and solution to same. Retorque till spec is reached and engine checks out as running properly- part of normal rebuild breakin proceedure.:hypnodisk:
