Newly Rebuilt Tractor Overheating
   / Newly Rebuilt Tractor Overheating #71
All I've said is totally relevant to the fix for this problem- as a result of professional knowledge gained from years of successful engine repair.
Come on, Coyote machine. The very FIRST response to the OP's thread suggested a bad head gasket. The next reply suggested re-torquing the head. Other advice followed. When dirtdonkey first responded to the assorted headgasket, radiator, water pump, and fill cap suggestions, he said he had already removed the head, re-inspected everything, etc. His words were "My first thought was the head gasket..." If he had already done that process, again, and verified everything was properly installed, I really don't think it is unreasonable to start looking elsewhere.
As background for you, dirtdonkey's tractor was made, at the latest, in 1981. The variety of grey-market tractors many of us have usually spent the first 20 or 25 years of their life in rice paddies in Japan. It was common practice for those farmers (for reasons I'm not entirely clear about) to fill the radiators with the silty rice paddy water to use as coolant. It is very common to have large amounts of silty crud, and the affiliated rust and other gunk, come out of the block when a thorough flushing is performed. Even new radiators have been blocked by the crud, and generally speaking, most head gasket failures are secondary to the tractor overheating, and this is overwhelmingly due to insufficient cooling. My point is simply this: Having already been told by the OP that the head and block have been trued, and having been replaced twice, it is not an unreasonable leap to start looking elsewhere, especially on machines that are notorious for having unusual problems with the cooling systems.
The way you're talking to Car Doc is totally out of line. He has offered excellent advice to many people here. You said
Logic would dictate to those who actually work on engines that bubbles in the overflow tank are MOST likely related to exhaust gases escaping from an improperly sealed head to block and caused by the gasket between them not doing it's job for any number of reasons. The fact that anti-sieze was used would lead me again toward what was done last- assembly of head to block and torquing of head bolts. Thus, checking actual torque tightness of the bolts after running the engine a few times through it's paces would reveal exactly what was revealed- loose bolts. Tighten bolts and run her again. Problem solved- case closed.
Which is exactly what WAS first suggested, and had been the first thing tried, all of which came after the suggestions to check the headgasket situation, and after the OP had already removed the head and inspected everything. How many times would you have him check or replace the same thing before moving on to other potential issues, especially given the known history of these machines for popping headgaskets from cooling issues? There's no reason to NOT be friendly here, either. You said
It may be plenty friendly, for the most part but not very constructive. I've seen everything under the sun thrown out as possible causes, from cracked blocks to bad caps, radiators, water pumps, head gaskets, hoses, foreign objects, etc.
Car Doc doesn't need me to stand up for him; he likely doesn't really care what you think. However, YOU don't need to be obnoxious or unfriendly. Telling Car Doc to go away is unbelievably rude. If you don't want to interact with him, leave. By post 22, dirtdonkey had fixed the problem, after replacing a headgasket, and re-torquing the fasteners after some run time. Once the guy's tractor is operating properly, I think everything is more or less handled. No one ever questioned your input until you started acting like a jerk; even then there's no question about the quality of the advice, merely the way it's been delivered. Be nice to people. There's no reason to be otherwise. I can see where you might have misunderstood Car Doc's comment about having a friendly conversation; that's still no reason to be unfriendly or impolite. Telling someone to leave a forum where they regularly contribute constructive, friendly posts is both unfriendly and impolite. I'm not the TBN police, but you're out of line for suggesting he leave and not come back, and owe him an apology.
   / Newly Rebuilt Tractor Overheating #72
I didn't misunderstand cardoc's comment to me at the beginning of what he chose to do, which is be sarcastic and rude himself.
Regardless of all the back and forth the fact is what I stated- retorque head bolts and for future reference don't use anti-seize in that application. I happen to be a skilled diagnostician, and others can suggest all kinds of other stuff- it is and was NOT the head gasket; it IS improper installation of same.
These forums are not person specific, they're PUBLIC forums, and anyone can participate. I did not tell guru car doc to leave until after he had suggested to me to do so. Regardless, you guys need to lighten up- contributions by new to a specific forum members adds insight into clearly confused areas where no new breath has breathed in ages if ever. Forget about an apology, it won't be happening. Move on to another topic.
   / Newly Rebuilt Tractor Overheating #73
...I happen to be a skilled diagnostician, and others can suggest all kinds of other stuff- it is and was NOT the head gasket; it IS improper installation of same....
I haven't seen where anybody questioned any of that.
I think it is also true your tone was/is out of line, and unfriendly. There's nothing further to be gained here by discussing this; you know you aren't being nice, and don't care. Your advice was correct, nobody has disputed that.
It would seem to some that you have revealed your character by acting as you have, but I've read some of your other posts in other sub-fora and you were much more polite. I find it unfortunate that one can have the ability to offer good advice, and still be unpleasant in interactions with other people. It doesn't help disseminate good information. I'm not sure why you have been so prickly here, but I look forward to reading polite, constructive advice from you and others wherever it is found.
   / Newly Rebuilt Tractor Overheating #74
Here's the thing. I contribute after reading a thread of interest and contribute as a means of sharing knowledge gained from years of experience in specialized fields of endeavor.
Those who share whatever on specific forums like the antagonist in this thread get bent out of shape when someone else suggest their line of thought is not topic specific.
I entered the discussion staying to not use antiseize on head bolts. This was immediately agreed with. Then cardok came in with Chevy v8 head bolts and moly lube. Irrelevant and not pertinent to the fix.
HE began with the sarcastic nasty remarks NOT me.
Again, I prefer to get the op on the right track and squelch any extraneous noise that might further confuse the issue like a lot of the wild guesses. Indian or Chinese water and possible crowding caught up in the water jackets also largely interesting but not the issue. The op had Abadan piston and did everything right for but one minor mistake- the addition of lube where none was warranted.
All the nonesense about if I have a yammer etc is crap.
I don't have to prove myself here or elsewhere.
I'm nice when treated with respect.
Otherwise the gloves are off until people come to their senses.
   / Newly Rebuilt Tractor Overheating #75
Again, I prefer to get the op on the right track and squelch any extraneous noise that might like a lot of the wild guesses.
All the none sense about if I have a yammer etc is crap.
   / Newly Rebuilt Tractor Overheating #76
But by that time the issue was resolved. He had replaced the head gasket, run the machine, and re-torqued the fasteners. Your advice was correct. It was also unneeded by that point, since he had done it already. The discussion about whether or not he should have used moly lube, anti-seize compound, or some other substance was, by then, an interesting and informative topic that was tangential to the original point.
I stand by my statement that you knew you weren't being nice. This feels like a kid going to another neighborhood's park and trying to change the rules of some other kids already playing Red Rover. There's no ownership of the field by any of the participants, but there is already a group using the facilities in their own way. Being upset when the kids don't play Red Rover the way you like it done isn't right or fair, and telling another kid to leave the park and not come back is out of line. I'm not saying you're being childish, merely not nice. Belligerence over diagnostic procedures on a tractor is silly to me, on anybody's part, whether it is their perceived turf or not. There are many people, in many places, who are in need of good diagnostic advice for their tractor's problems. You have helped many people with polite, useful, systematic advice. That was not the case here, and you shouldn't feel any need to have your "gloves off" until we come to our senses. Just play nicely and let other people do the same, especially when the game you want to help them figure out has already been over for awhile.
   / Newly Rebuilt Tractor Overheating #77
Typical multipage TBN thread; problem resolved, yet somebody is still dancing around the fire beating his chest claiming to be more 'right' than anyone else.
Get over yourself already, cm.
   / Newly Rebuilt Tractor Overheating #78
The strange thing here is that this Yanmar forum is one of the most civil groups on TBN, or online anywhere. These tractors we discuss are orphans. Yanmar departed the US market 20?? years ago, then gray market importers brought over a flood of Japanese-spec Yanmars. This community of interested owners is the primary support (along with a few major mailorder parts dealers) for nearly all the Yanmars in the US. (Recent model Yanmars have dealer support and warranties so only a few of their owners show up here).
And - these old Yanmars are simple. When a newbie shows up with a problem and asks for others' experience on his issue, usually several people respond describing the last several times that question was asked, and answered. Substantial mutual respect has developed here over the years.
CM, you don't realize what you walked into. You seem oblivious to the cultural clues here - different people express different levels of expertise but all the present participants do so with obvious mutual respect. The poster you have been arguing with owns an auto repair shop, while you have offered nothing to substantiate your claimed vast experience. I wonder if your experience is half of his.
When I first started reading here the Kioti forum was a joke to everyone else, it was full of posters with attitude. The moderators were needed constantly. Several owners got banned when they didn't have the sense to tone down their meanness. This Yanmar forum has never sounded like that and I don't think that approach would get any traction here.
Now - if you have something to add to any of these threads that broadens our knowledge we would love to hear it.
   / Newly Rebuilt Tractor Overheating #79
I personally watch Car Docs posts very carefully. Time has proven them to be a great asset here. Seems to me he always posts with humility. I will be the first to admit a lot of my ideas are hogwash but I don't try to present them as factual.
   / Newly Rebuilt Tractor Overheating #80
Stand by whatever you want and tell me that my point was tangential, and un-necessary all you want. All you and others who follow are proving is that those on this forum are a tight knit group of Yanmar followers who aren't interested in anyone's input except their own. Fine, follow yourselves around and lavish praise. Close mindedness and groupthink will not help you Yanmar guys get any new insight into your special way of doing things no matter how convoluted.
Criticise me all you want, but look at who started the; 'we're just having a friendly conversation here if that's alright with you' comment. It WASN'T me.
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
INGERSOLL RAND 175 PORTABLE AIR COMPRESSOR (A51244)
INGERSOLL RAND 175...
2015 JOHN DEERE 60G EXCAVATOR (A51242)
2015 JOHN DEERE...
Corn Reel (A50514)
Corn Reel (A50514)
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51243)
2000 TRAILKING...
