NH 1720 Wants to tip over
   / NH 1720 Wants to tip over #1
VetRick
New Holland 1720
NH 1720 tips dangerously to the right even on level ground. It is a 4WD with a FEL. Problem started a few months back when operating on wet ground while moving hay rounds but has gotten worse to the point that left rear wheel has come off the ground. Now it happens even when there is no load on the loader. Any thoughts on where the problem could be? Wheel, differential, axle? Front axle is on a center pivot pin and there is no discernable leakage or disconnected parts. Thanks! Any help is welcome.
   / NH 1720 Wants to tip over #2
Astounding! Unnaturally twisted. Need pics.
   / NH 1720 Wants to tip over #5
Seeing tractor design I have a really hard time understanding your problem.... Maybe tire pressure is about only thing other than bad load balance in FEL...
Might try wheel spacers to widen the rear track for more stability...
   / NH 1720 Wants to tip over #6
Check to see if you have cracked frame as a result of picking up the hay rounds.
   / NH 1720 Wants to tip over #7
It would be very interesting to see a video of both sides with this happening.
   / NH 1720 Wants to tip over #8
I would be inclined to maintain a comfortable distance from that tractor.
   / NH 1720 Wants to tip over #9
Agree with previous comments. I would be inclined to check the loader frame.
   / NH 1720 Wants to tip over #10
You mention that it happens with no load. Does that mean it happens just driving straight on level ground or are you maybe making a hard turn. If this happens just driving straight on level ground then I can't even imagine a cause. Do you have a dealer close that you could discuss this with?
2015 Chevrolet Tahoe (A55853)
2015 Chevrolet...
Adams 6 Ton Hydraulic Lime Spreader (A55301)
Adams 6 Ton...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
New/Unused Quick Attach Auger with Bits (A54865)
New/Unused Quick...
