NH 7308 Loader Owners
   / NH 7308 Loader Owners #231
The tester was just a quick connect on one end, a hose, and a gauge on the other end. If your dealer's maintenance shop can't help you build one a hydraulic shop should be able to. Maybe someone can chime in here with the proper type of quick connect.
   / NH 7308 Loader Owners #232
Ive seen a lot of threads hear on TBN.
This is one of the best ive ever seen! Not only in terms of people working together for the common good. but the shear amount of GOOD reliable, factual info thats contained.
I have a rhino loader which is the same as the 7308 and would LOVE to put a guage on mine.
Any thoughts to putting together a new guage and starting this up again? (ive found that if i want something myself i generally have to just go ahead and do it)
   / NH 7308 Loader Owners #233
Well, I have to have it again, my pressure setting is leaking oil again, so I will need to change o-rings again and reset.
If you want to wait a bit, I will try and do this next couple weeks, I need to get a day off where I have the tractor on the trailer with the hydraulic store open to give me a hand, but after I get it done, I would be happy to lend it too you. I was one of the original benefactors.
   / NH 7308 Loader Owners #234
Newbie to the Forum, Just got a TC25D and need a loader for it. Any help would be appreciated guys!
Thanks,
Dan
   / NH 7308 Loader Owners #235
Don't know if this is a dead thread, but my loader and HST on my 1530 are acting up. Fast dump has stopped working and loader has always had a problem lifting a full bucket of material ie sand/dirt. The fast dump use to work now it's slow and seems slower than ever. My HST also has started to make a high pitched sound when the pedal is pushed totally forward or reversed, not evident while half depressed.
Any idea what's causing it?
Hydraulic oil is at the full mark. Tractor has only 254 hours and planning to do a complete oil and filter change soon.
Many thanks!
Ed-
2324 (A58376)
2324 (A58376)
Mini Plate (A57149)
Mini Plate (A57149)
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2117 (A58376)
2117 (A58376)
2022 Horizon (A55973)
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
