NH liftarm w/ broken flex-end catch
   / NH liftarm w/ broken flex-end catch #1
mudking
NW Piedmont, NC
1991 Case 5140 Cab MFD w/FEL, 2001 New Holland TN 75D Cab, 2006 Case JX95 Cab MFD, 2022 Yanmar YM347 open-station, FEL.
Hi.
One of the liftarms on my 1995 NH 3930 has a flex-end that recently started extending all by itself under load (boxblade). Upon inspection, the roll-pin looking thing on the catch-mechanism (that indexes a hole facing inward, toward the PTO shaft) seems to have broken away.
Does anyone have any wisdom to share on this before I attempt repairs uninformed?
Thanks,
MK
   / NH liftarm w/ broken flex-end catch #2
I replaced both of the roll pins with hardened bolts, washers and locknuts. Not having great access to lock nuts (I wanted something better than those nylock type) I simply squeezed a couple of regular, but grade 5, I think, nuts and then also used locktite. The problem I had with the roll pins is that nothing holds the saddle-type assembly from spreading slightly, and then sand and gravel got in between the arm and the mechanism and really bound things up. I think I used 5/16" or 3/8" bolts and had to slightly drill out the holes.
Thanks djradz, That fix makes sense to me. I'm going to try it.
Regards, MK
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
