NH liftarm w/ broken flex-end catch
   / NH liftarm w/ broken flex-end catch #1
mudking
NW Piedmont, NC
1991 Case 5140 Cab MFD w/FEL, 2001 New Holland TN 75D Cab, 2006 Case JX95 Cab MFD, 2022 Yanmar YM347 open-station, FEL.
Hi.
One of the liftarms on my 1995 NH 3930 has a flex-end that recently started extending all by itself under load (boxblade). Upon inspection, the roll-pin looking thing on the catch-mechanism (that indexes a hole facing inward, toward the PTO shaft) seems to have broken away.
Does anyone have any wisdom to share on this before I attempt repairs uninformed?
Thanks,
MK
   / NH liftarm w/ broken flex-end catch #2
I replaced both of the roll pins with hardened bolts, washers and locknuts. Not having great access to lock nuts (I wanted something better than those nylock type) I simply squeezed a couple of regular, but grade 5, I think, nuts and then also used locktite. The problem I had with the roll pins is that nothing holds the saddle-type assembly from spreading slightly, and then sand and gravel got in between the arm and the mechanism and really bound things up. I think I used 5/16" or 3/8" bolts and had to slightly drill out the holes.
Thanks djradz, That fix makes sense to me. I'm going to try it.
Regards, MK
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
40ft Shipping Container (A52377)
40ft Shipping...
