NH liftarm w/ broken flex-end catch
   / NH liftarm w/ broken flex-end catch #1
mudking
NW Piedmont, NC
1991 Case 5140 Cab MFD w/FEL, 2001 New Holland TN 75D Cab, 2006 Case JX95 Cab MFD, 2022 Yanmar YM347 open-station, FEL.
Hi.
One of the liftarms on my 1995 NH 3930 has a flex-end that recently started extending all by itself under load (boxblade). Upon inspection, the roll-pin looking thing on the catch-mechanism (that indexes a hole facing inward, toward the PTO shaft) seems to have broken away.
Does anyone have any wisdom to share on this before I attempt repairs uninformed?
Thanks,
MK
   / NH liftarm w/ broken flex-end catch #2
I replaced both of the roll pins with hardened bolts, washers and locknuts. Not having great access to lock nuts (I wanted something better than those nylock type) I simply squeezed a couple of regular, but grade 5, I think, nuts and then also used locktite. The problem I had with the roll pins is that nothing holds the saddle-type assembly from spreading slightly, and then sand and gravel got in between the arm and the mechanism and really bound things up. I think I used 5/16" or 3/8" bolts and had to slightly drill out the holes.
Thanks djradz, That fix makes sense to me. I'm going to try it.
Regards, MK
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
