NH/Rhino loader for 07 TN's
   / NH/Rhino loader for 07 TN's #1
LoneCowboy
so, went by the dealer today, and had him price out a TN75 both cab and non cab.
One thing that caught in my head was that he said the new NH loaders suck.
They are quick attach, but only for NH attachments only. (which pretty much defeats the point)
He said they are ordering everything with Rhino loaders, which is who used to make the NH loaders.
Any word on this?
So, he'll send me a quote on tuesday or so, see what we can put together (i.e. see if I can make a business case for it)
I asked about 3 remotes, loader, power shuttle, gas tank skid plate, what else???????
   / NH/Rhino loader for 07 TN's #2
Looks good. Cost???
Block heater?
Bob
   / NH/Rhino loader for 07 TN's #3
I'm not sure what all that you are going to be doing with your tractor, so I will list a few options you might consider in addition to what you have listed.
canopy if you get the ROPS tractor
R4 or R1 tires?
fill tires
wheel weights
front end weights
rear work lights
electric diverter valve for grapple or?
top 'n' tilt for 3ph
I know that I'm forgetting something, but there's a start. Remember that you most likely will not get as good of a deal on options after the initial purchase. So try to get any and all that you might need and that you can afford.
Good luck:)
he's putting a quote together for me (with a 8' mower and a 8' Aerway -- my biz)
I did ask for a block heater.
R4's make the most sense for me
I did ask about both front and rear weights. That aerway gets HEAVY without a FEL on (even with a FEL on)
What's a top 'n tilt????????
That's a new one on me.
I asked about mirrors
Rear work lights,hmmm, that's a good idea too.
I'm sure we'll go back and forth a couple times.
   / NH/Rhino loader for 07 TN's #5
Ok, I'll tell you what Top'N'Tilt is if you tell me what Aerway is.:confused:
Top is a hydraulic cylinder in place of the top link of the 3 point hitch. (great for implement hookup and adjustment of angle on implements) Forward and backward angle.
The tilt portion is a hydraulic cylinder in place of the right hand side link of the 3 point hitch. ( this gives you side tilt of implements and also is another easy adjustment to help hookup to implements)
The T'N'T system is great with box blades, rear blades, landscape rakes, just about any fixed type of implement that you would hookup to the 3PH. This would use up 2 of the 3 rear remotes that you have asked for.
Hopefully this helps.:)
   / NH/Rhino loader for 07 TN's #6
LoneCowboy said:
one thing that caught in my head was that he said the new NH loaders suck.
NH quick attach is same as Bobcat. Bobcat is probably the most popular in the industry.
   / NH/Rhino loader for 07 TN's #7
The new TL series loaders for NH are manufactured by ALO/Quicke, and have the new ISO standard quick attach system, which is not skid steer attach. JD is also converting to this sytem, as will other loader manufacturers, as it is the new world wide standard. I'm sure that someone out there will manufacture an adapter to allow the use of skid steer QA on these loaders.
   / NH/Rhino loader for 07 TN's #8
Ya beat me to it:D That answer is 100% correct.
super
but basically anything you buy today for skid steer QA won't fit.
How worthless is that?
Why would they do a new standard different than the currently accepted 90% standard? typical government BS
   / NH/Rhino loader for 07 TN's #10
Hum! Let's see; how about; we can sell a bunch of new attachments to owners ! Then, we can come out with a new 3 point hitch dimension, and we can sell new attachments for the rear.
2018 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 FREIGHTLINER...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
*Selling at Royal Auction Zephyrhills, FL Location* (A59231)
*Selling at Royal...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
