NH TD5.95 drifts to the right - worse when faster
   / NH TD5.95 drifts to the right - worse when faster
Least of its worries now - I had nearly finished tedding a 5 acre field when there was a bleep, a stop symbol and some error relating to the diesel particulate filter. I should have made a note of the error code but thought I had better stop the engine immediately. Awaiting call back from dealer but I think I have found a way to access the historic error codes.
Well, the dealer has nobody who could come out to the machine but I did find out in the manual how to access the error codes. Except I couldn't. It repeated a symbol which I think refers to the engine running on reduced power. After more conversations with the dealer, I decided to give it another go. I noticed that the amber warning symbol also flashed with a few beeps. I think it was three then two then one. Suddenly the warning symbol went out and the tractor started! The dealer person suggested I start a manual regeneration except it does not allow that unless it needs it.
When I just attempted to access the historic error codes, there aren't any! Aaargghhh!
I hope it does not happen again.
It did with a different error code - 3293. I will start a new thread as that number is not in the manual too.
Back to the original problem and steering to the right. A local NH expert had a drive and he told me not to drive it on a road until it is fixed! He suggested that it is indeed a leaking seal but the leak is internal to one of the power steering rams. I think the work required is beyond my meagre skills so I need to find someone appropriate. Thank you all who replied. I think it has had this problem since I bought it but thought it was me!
2025 Heavy Duty D Ring Shackles (A55788)
2025 Heavy Duty D...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2014 Dodge Avenger Sedan (A55758)
2014 Dodge Avenger...
2015 Ford Econoline Shuttle Bus (A55788)
2015 Ford...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
