Robert_in_NY
Super Member
- Joined
- Aug 1, 2001
- Messages
- 8,552
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
WeedHopper said:I have 2 friends with new Deeres and they carp about small and large problems as well. I do think the overall quality of the Shibaura New Hollands is somewhat better than the Fiat built units and the Mexican built units have some rough spots and are looking more like Chinese built tractors. One would think they could do a better job with paint and wiring. The paint is probably attributable to bad or no prep. The wiring is bad engineering combined with second-rate connector vendors. Hey Fiat, why don't you check out the AMP catalog and buy some decent connectors for a product that is typically stored outside? Couldn't add more than $20 to the cost of the tractor. DUH! Instrument clusters failing is ridiculous. The user depends on the instruments to monitor the operating condition of an expensive piece of equipment. They should be durable and designed to last the life of the equipment and for a tractor that means they need to last at least 10 years. Idiot lights that fail in a year or two and hour meters that stop working before they even get to 1000 hours is just wrong. If there were enough angry owners the lawyers would jump in with a class action suit and sooner of later NH owners would get a discount coupon for a new plowThe problem is that tractors are manufactured in relatively small quantities by a relative few manufacturers. There is much less competition than there used to be both at the manufacturers level and the dealer level. The bottom line is that there aren't any perfectly made tractors and if you don't believe me check out any of the other brand forums. As for me, I am fond of blue and bought a TN because of the color, even though it is flaking off
Where is the paint flaking off your hood? Most of the hoods the paint comes off in the center directly above the muffle (I am thinking it is a heat related issue). I have seen a couple where the paint is also coming off the front corner on the older TN's where they actually had corners on the hoods. I do not know if it is poor prep, poor paint or damage by the operator of the tractor. So far my bald spot is only about a 6" by 4" spot with the very beginning of some rust starting to show thru the primer. I figure as old as the tractor is right now (7 years) I will give it some more time and then just repaint the hood and touch up a few other areas.
