No electric 12v power to the cab
   / No electric 12v power to the cab #21
I got the two images from the Mahindra parts list under you tractor name. Go to the section that covers the Electrical & Harness you'll find them.
   / No electric 12v power to the cab #22
Look for a ground strap to the cab.
Connect a cable to the cab for a ground and see if it will light a test light at the battery.
Does it say download start and then I have a pop-up at bottom that shows name of file and Open ,but. It doesn't last very long
It says : Do you want to download I say yes it disappears back to the post
   / No electric 12v power to the cab #24
Can anyone else open the pdf files?
   / No electric 12v power to the cab #25
do you see a small window appear at the bottom, its only there for a few seconds and should have OPEN on the right side
   / No electric 12v power to the cab #26
The PDF file worked fine for me. If your browser is set to automatically doownload to the download folder it is probably there. Most browsers are set to that by default. I change that setting to always ask so I can put files where I want or view them in the browser.
Finally got both to download
   / No electric 12v power to the cab #29
Not a wiring schematic, but should help in isolating problem.
If you don't yet have, you need a multimeter and also a voltage circuit probe.
You need to start at the fuse box And check for voltage, and you need to ohm out the fuses.Since everything is dead you need to be sure voltage is at box and grounds.
I didn't see anything in cab wireing that that would cause the problem.
Also I would check harnesses for any mouse damage to wiring.
I will chk and from the harness into the cab from the firewall I have nothing as far as power.
I work nights so I’ll be checking it out when I’m back up.
thanks
Kubota L3830 (A57148)
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2017 Wacker Neuson LTV6L Light Tower (A56857)
2017 Wacker Neuson...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab Pickup Truck (A56858)
2018 Chevrolet...
