No Electrical Power to dashboard
   / No Electrical Power to dashboard #1
harkengator
Dunnellon
LS G3033
I have a 2014 LS G3033 tractor. The other day I attempted to start the tractor. The starter briefly engaged, about 2 seconds but had a sudden loss of power. I checked the battery connections and the battery level of charge and both were fine. I then began to troubleshoot the electrical starting with the keys switch which has 12 volts. However, the dashboard digital display and analog gauges have no power. I moved on to test the relays and the connectors and all had power. Of note I thought of the fusible link bing bad. The problem is that if the fusible link was bad then there would be no power after the battery.
   / No Electrical Power to dashboard #3
Check the ground wire connection point. If everything is good for a second or 2 then goes blank, almost always ground related. On mine i kept having intermittent issues, Then finally had wife hold key on start while i twisted cables. When i twisted ground cable on battery, vroom, tractor started. I fixed problem and never recurred....3 years ago.
   / No Electrical Power to dashboard #4
if your battery is good (tested and 12.6V charged) and you are only reading 12V you have a bad ground to start with.
What is the fuseable link you are testing feeding? May not be for the dash. Usually they feed up to a fuse box and other full time voltage.
Your problem could also be from the fusebox out to the dash.
2018 Gatormade 20+5 Gooseneck Trailer (A55301)
2018 Gatormade...
2024 Frontier FL1061S Hydraulic Flail Mower (A55302)
2024 Frontier...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
KEWANCE 200 9' GRADER BLADE (A54756)
KEWANCE 200 9'...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A55853)
2022 McConnel...
