No Electrical Power to dashboard
   / No Electrical Power to dashboard #1
harkengator
Dunnellon
LS G3033
I have a 2014 LS G3033 tractor. The other day I attempted to start the tractor. The starter briefly engaged, about 2 seconds but had a sudden loss of power. I checked the battery connections and the battery level of charge and both were fine. I then began to troubleshoot the electrical starting with the keys switch which has 12 volts. However, the dashboard digital display and analog gauges have no power. I moved on to test the relays and the connectors and all had power. Of note I thought of the fusible link bing bad. The problem is that if the fusible link was bad then there would be no power after the battery.
   / No Electrical Power to dashboard #3
Check the ground wire connection point. If everything is good for a second or 2 then goes blank, almost always ground related. On mine i kept having intermittent issues, Then finally had wife hold key on start while i twisted cables. When i twisted ground cable on battery, vroom, tractor started. I fixed problem and never recurred....3 years ago.
   / No Electrical Power to dashboard #4
if your battery is good (tested and 12.6V charged) and you are only reading 12V you have a bad ground to start with.
What is the fuseable link you are testing feeding? May not be for the dash. Usually they feed up to a fuse box and other full time voltage.
Your problem could also be from the fusebox out to the dash.
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
Miller Bobcat 250 Diesel Welder (A54865)
Miller Bobcat 250...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
