no hi idle 440 b bobcat
   / no hi idle 440 b bobcat #1
lmkdriver
MACKENZIE B.C
440b bobcat
Hello all I have a interesting problem I bought a new carb , fuel filter , pickup tube ,fuel pump used but seems to have good pressure . My 440 b 18 hp kohler [gaspot] wont go above idle it tries to stall out I am wondering if maybe it is governer related any indeas any information or ideas would be helpful.
   / no hi idle 440 b bobcat #2
What happens if you close the choke some when throttling up? If it tries to gain RPM with choke closed, problem is fuel supply. Could be float height adjustment or fuel/air mixture screw(s) not correct. Just because it is new carb does not mean it is set correct.
Have you checked the ignition electrical?
You may get more response and help from those familiar with Kohler engines if question is posted in Parts & Repairs.
   / no hi idle 440 b bobcat #3
Something blocking main jet. Perhaps water. Perhaps a particle.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
UNUSED FUTURE HWG44 44" HYD HOLLOW WOOD GRABBER (A57193)
UNUSED FUTURE...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A52707)
2016 CATERPILLAR...
LaneShark LS4 46" Front Mounted Brush Cutter (A56469)
LaneShark LS4 46"...
2016 Kubota SVL 75-2 (A53317)
2016 Kubota SVL...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
