No more V8 in F150?
   / No more V8 in F150? #241
Technically a 3.5L engine at about 14PSI of boost is displacing about 7L on each revolution. Not often does the ecoboost run at 14PSI, but it can as needed. It's not really replacing displacement, it's just using boost/compression to fit it in a smaller package and deliver it on an as-needed basis.
   / No more V8 in F150? #242
A 7liter displacement engine is equal to 3.5 liters and 1 bar or 14.7 pounds of boost. So from a pure mathematical standpoint, psi is a substitute for displacement.
   / No more V8 in F150? #243
As the fleet tests continue to prove the 3.5 ecoboost to be a longer lasting, harder working engine than the V8, the V8 demand will shrink significantly.
I think the difference for which line they get built on is more to do with the frame length/wheelbase than the bed sizes.
Mostly, however the 8' bed trucks (reg cab with 8' is same length as super cab / 6.5' bed or crew cab / 5.5' bed) are all built at KCAP.
   / No more V8 in F150? #244
I understand, I was just pointing out the only specifics based on bed size that I know of. The 6.5' boxes are built in both places. The 8' boxes are not.
OK, Thanks
   / No more V8 in F150? #246
Same one they're using in the van, yep. Power output hasn't been announced, but most are speculating that it will be less than both the gasser V8 and 3.5L ecoboost, figuring it will be tuned for fuel economy to compete with the Ram ecodiesel.
I thought the 3.2 in the Transit is an inline 5 built by Mazda...
The van diesel is an inline 5, not sure if Mazda builds it though.
   / No more V8 in F150? #249
Ford Duratorq engine - Wikipedia
Elsewhere i read that the Mazda B50 is replaced by a badge engineered Ranger, and the B50 didnt use this engine yet...
3.2 five would mean a 2.5 four.. what engine would it be based off then, because all other Ford diesels are Peugeot designs which replaced the old Transit 2.5 diesel... and in the landrover a V6 is used instead...
   / No more V8 in F150? #250
The 3.0 V6 going in the F150 is not the same as the 3.2 I5 in the Transit vans. It's essentially the same 3.0L Lion V6 used by Jaguar/Land Rover.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
