No oil on air filter precleaner?
   / No oil on air filter precleaner?
Must have been a lot of "user" oiling errors out there, my JD 318 has ran fine for 27 years with an oiled foam pre-cleaner and normally I'd only clean it once a year. It would be caked with dirt at the end of the season but the paper filter remained clean and I'd usually go 3 or 4 years between changing it. When oiling the foam filter I'd always squeeze the crap out of it until no oil oozed out of it.
I'm hesitant to go with a dry filter because it seems like it would let a lot more dust through to the paper filter.
I wonder if the warranty would be voided on my X739 if I oiled the pre-filter?
   / No oil on air filter precleaner? #12
I think it was the material they started using was allot finer that even hardly any oil would plug them. We have used many filter in the past that required a little oil and no issues.
Must have been a lot of "user" oiling error out there, my JD 318 has ran fine for 27 years with an oiled foam pre-cleaner and normally I'd only clean it once a year. It would be caked with dirt at the end of the season but the paper filter remained clean and I'd usually go 3 or four years between changing it. When oiling the foam filter I'd always squeeze the crap out of it until no oil oozed out of it.
   / No oil on air filter precleaner? #13
If you want to oil it, go for it. The worst that could happen is the paper filter clogs and you have to buy another one along with a new foam outer.
   / No oil on air filter precleaner? #14
Why would the paper filter clog? A PROPERLY oiled prefilter will keep more dirt from getting to the paper filter. A SMALL AMOUNT OF OIL. No pores in the foam should be filled with oil, just a VERY light coating.
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
(3) 12"X40#X86.5" I BEAM (A58375)
(3) 12"X40#X86.5"...
SHOP TOOLS (A58216)
SHOP TOOLS (A58216)
Bush Hog 3815HD (A57148)
Bush Hog 3815HD...
Hays LTI PTAT180RD Seed Tender (A57148)
Hays LTI PTAT180RD...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
