No welder, no torch, no anvil, NO PROBLEM
   / No welder, no torch, no anvil, NO PROBLEM #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
Well, it was a bit of a problem but I needed a two inch ball attachment for my box blade and looked for options based on the equipment and materials I had available.
So, I used
(1) an old piece of flat iron
(2) a Saws All with metal saw to cut it the right length (an amazing tool)
(3) iron and pipe on my trailer to pry the iron piece into correct shape
(4) a two inch ball unit that got bent during this episode
http://www.tractorbynet.com/forums/trailers-transportation/159210-too-much-slope.html
(5) a drill with an expensive bit
Here's what I got. Nothing fancy but it works.
   / No welder, no torch, no anvil, NO PROBLEM #2
:thumbsup:Who said that "Necessity is the Mother of Invention"? Or how about "Invention breeds success". Being a non-welder, I've been there....but still wish that I could weld. I've got so darn many tools now that are rarely used, I'm not going to start buying/learning welding.:(
   / No welder, no torch, no anvil, NO PROBLEM #3
I have welding toys etc. But to support you I would have done the same as you did. I would have choosen to bolt it on the reason being , it is easily unbolted.
I do not like grinding off welded brackets.
But if you are going to play with blades and such electric welding is needed as they do get stress cracks
Craig Clayton
   / No welder, no torch, no anvil, NO PROBLEM #4
Hey if it works I say congrats.
   / No welder, no torch, no anvil, NO PROBLEM #5
The true test of anything is wheither it works!
It does work. I did not think the metal edge on the box blade was enough to keep the hitch in place. The piece of flat iron gives it some stability and great support.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
