Noisy 54 inch Snowblower attached to JD x749
   / Noisy 54 inch Snowblower attached to JD x749 #21
Shouldn't be squealing at all but a good blower will roar from impeller air flow at high RPM.
The best guess I gave is that either something is behind the impeller or the impeller is rubbing.
   / Noisy 54 inch Snowblower attached to JD x749 #22
The 54" front-mount I have with my 2520 didn't get much use this past winter... But... When I was running it, there was no "significant" increase in sound / noise levels over just the tractor itself running at 2500RPM.
The largest amount of sound increase seems to be a loud "hum" accompanies by the moving air. It sort of "chug-chug-chugs" its way along.
When you pack it full of a yard of snow and make it move it, the noise level drops down again. I can have a conversation with a bystander while it's running, tho... And the elevated volume for speaking is to get over the engine noise.
   / Noisy 54 inch Snowblower attached to JD x749 #23
I have a x749 and 54" Blower, no major noise issues for me. You will hear a little more noise when it is fully raised due to the drive shaft angle but it is still not as loud as the engine.
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
