Non Kubota Oil Filter
   / Non Kubota Oil Filter #1
Thomasre
North Carolina
Kubota L3430 + BX2230
I'm preparing to do 200 hr maintenance on L3430 can I use a non-kubota brand oil filter? Not good idea? Fram #? Amsoil # Anyone else doing this with oil / hydro filters?
   / Non Kubota Oil Filter #2
My dealer strongly recommended FleetGuard
   / Non Kubota Oil Filter #3
The last time I looked I did not find any filters other than Kubota for the Lxx30 series. If you do find them please publish the info
Vernon
   / Non Kubota Oil Filter #4
I use WIX. They have a solid reputation, and nearly every farmer in the area uses WIX in their equipment. I don't know who makes filters for Kubota, but I do know that WIX works. Wix has a web site which should cross reference your filter numbers if they make an equivalent filter.
   / Non Kubota Oil Filter #5
I second WIX filters. Great filters at a reasonable cost. Many companies re-brand WIX filters for their own use. I know NAPA Gold filters are WIX around here for instance.
   / Non Kubota Oil Filter #6
I just checked and WIX lists only air and fuel filters for the L3130 and the L3430; for the L3830 they also list an oil filter if your engine model number matches.
Vernon
   / Non Kubota Oil Filter #7
I just checked and WIX lists only air and fuel filters for the L3130 and the L3430; for the L3830 they also list an oil filter if your engine model number matches. I did not check the other Grand L models.
Vernon
   / Non Kubota Oil Filter #8
Napaonline.com list two oil filters for the L3430. Just put in the non napa filter #.
I have Napa filters on my Mitisibisi 372D cut , Cat C13 in a Peterbilt and many other weird applications in the past. Napa is good for the non everyday parts.
   / Non Kubota Oil Filter #9
We have a kit that has the guts a few differnet filters torn apparet so you can see the differences. There are pictuers on our website. The WIX filters seemed pretty good, I'd shy away from FRAM - those look shotty.
   / Non Kubota Oil Filter #10
neal, you mispelled that one word, i have seen the inside of frams also and it's not spelled with an "O"
91013 (A48082)
91013 (A48082)
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
