Snowblower Normand Snowblower on 3320
   / Normand Snowblower on 3320 #11
It is 54 inches. 1/2 inch narrower than what the tractor tires are set at right now. It was too good of a deal to pass up on for a used blower. List price was close to 9000 dollars and I picked it up for 1750. The blower had 8 hours of use on it and came with an extension for loading into a truck. I could narrow up the rear tires, but I like them where they are at. Seems to be working real nice. It really launches the snow compared to my old JD 666 blower. The blower is rated for 50-90 HP but I am real pleased with it at 33 HP
You could always make little extensions, say total of 3", (1 1/2 per side), to keep clear of your track width otherwise you will eventually find that you will be compacting snow with your wheels and end up with a shallow luge run.
I know, I had a 48" blower on 48" wide rear track and it was not pleasant.
Nice blower, but then 'Fait au Quebec' LOL (made in Quebec)
I am going to put some little extensions on it just not sure if 1/2 or three inches. I think I will go with three inches as the blower is so heavy duty and and get great traction with the r
I am going to put some little extensions on it just not sure if 1/2 or three inches. I think I will go with three inches as the blower is so heavy duty and it has the capactiy and I get great traction with the r1 tires. This will get me to 60 inches. Somebody on here posted some real nice extensions and I am going to copy them.
   / Normand Snowblower on 3320 #14
The blower is rated for 50-90 HP but I am real pleased with it at 33 Hp
Who rates the blowers any way? Do they expect you to do 30mph wile blowing snow? My 84" blower is rated for 50 or bigger and my 3320 dose just fine. As long as the snow isn't coming over the top of the intake the tractor dose not bogg.
I think it the manufacturer that rates them. If I was cleaning two foot tall sidewalks though I would want more HP just so that I could go faster. Luckily with the hydro I can make it work real nice for my yard and driveway.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
POLY TOTE W/ METAL CAGE & PALLET (A52708)
POLY TOTE W/ METAL...
(3) ALUMINUM STEP LADDERS (A58374)
(3) ALUMINUM STEP...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2016 Ford F-350 4x4 Crew Cab Utility Flatbed Truck (A55973)
2016 Ford F-350...
