Novice question about hydro motors
   / Novice question about hydro motors #1
Lawnjocky
Central Illinois
JD 3520
I don't know much about hydraulics so I need a little help choosing a motor. I think the motor I need is a Char-Lynn H series 101-1753. but I can buy the 101-1001 for $25 less. The only difference I can see and understand is the lower cost motor has a higher flow 2.8 vs 2.2. Should I spend the extra $25 or will the bigger motor work. All I'm doing is rotating a chute on a snow blower.
   / Novice question about hydro motors #2
The chute rotator motor on my Kubota front mount blower is quite small and has restrictors in both lines and still spins the chute about twice as fast as I need it to:eek:. No matter which motor you choose, power and speed will not be a problem.
   / Novice question about hydro motors #3
Bigger motor will turn slower....but with more torque...
   / Novice question about hydro motors #4
Why not put flow dividers to the hyd motor. You could set up a hyd circuit to turn the chute at a certain speed. Say your tractor has a 10 GPM pump, and you had a 2/8 splitter, the one circuit gets 2 GPM, and the other 8 GPM goes back to tank.
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5911&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5302-25&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-4169-8&catname=hydraulic
I have a valve similar to the bottom valve, in my PTO circuit, and I can dial in the rpm of the hyd motor, and the excess goes back to tank..
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
golf cart (A55758)
golf cart (A55758)
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
