Novice question about hydro motors
   / Novice question about hydro motors #1
Lawnjocky
Central Illinois
JD 3520
I don't know much about hydraulics so I need a little help choosing a motor. I think the motor I need is a Char-Lynn H series 101-1753. but I can buy the 101-1001 for $25 less. The only difference I can see and understand is the lower cost motor has a higher flow 2.8 vs 2.2. Should I spend the extra $25 or will the bigger motor work. All I'm doing is rotating a chute on a snow blower.
   / Novice question about hydro motors #2
The chute rotator motor on my Kubota front mount blower is quite small and has restrictors in both lines and still spins the chute about twice as fast as I need it to:eek:. No matter which motor you choose, power and speed will not be a problem.
   / Novice question about hydro motors #3
Bigger motor will turn slower....but with more torque...
   / Novice question about hydro motors #4
Why not put flow dividers to the hyd motor. You could set up a hyd circuit to turn the chute at a certain speed. Say your tractor has a 10 GPM pump, and you had a 2/8 splitter, the one circuit gets 2 GPM, and the other 8 GPM goes back to tank.
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5911&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5302-25&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-4169-8&catname=hydraulic
I have a valve similar to the bottom valve, in my PTO circuit, and I can dial in the rpm of the hyd motor, and the excess goes back to tank..
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
