Now Hydro Filter Not On Tight Enough!
   / Now Hydro Filter Not On Tight Enough! #1
HarleyBob
Puget Sound, WA.
Ok, so I banged the filter off with a punch and hammer.
The manual for the L3010 HST says turn the Hydro-Transmission filter 1 turn after contact. There are markings on the side of the filter to help you guage 1 turn. I can only
turn it 1/4 to 1/2 with a major long handle filter wrench.
It is tight, but not 1 turn. It does not leak when running, YET.
Anyone else have experience with tightening this filter and if 1 turn is necessary?
   / Now Hydro Filter Not On Tight Enough! #2
I have only hand tightened every oil filter I've ever put on, hundreds, and never had one leak. My hands are not big and I'm not that strong either. This includes the hydro and oil filters on my L3130.
   / Now Hydro Filter Not On Tight Enough! #3
The way I see that recommendation is to ensure that people try and get that much turn out of it. I never remember getting a full turn out of one. I think it's for those people that may cock the filter to one side while installing it and start the 1 turn as soon as that one place is touching. That way 1 turn would give you about what you got in your half-a-turn.
   / Now Hydro Filter Not On Tight Enough! #4
"the filter to help you guage 1 turn. I can only
turn it 1/4 to 1/2 with a major long handle filter wrench."
Exactly what kind of "major" wrench are you using?
I was able to turn mine the correct amount, 1 full turn. Are you sure you have the correct filter? J
My filter is from Kubota and is exactly the same as the original. Threads fit fine. The gasket does not protrude much from the base, so I don't see how it cold turn much more than 1/4 turn without starting to strip threads.
   / Now Hydro Filter Not On Tight Enough! #6
I've probably missed the entire point here .
But, if it's not leaking ( yet ) , then there isn't a problem /forums/images/graemlins/smile.gif
The filter is filtering ,and the seal is sealing . All is good in tractor land /forums/images/graemlins/smile.gif JMHO , John
   / Now Hydro Filter Not On Tight Enough! #7
On my 3010 and now 3130 I tightened the HST filter as tight as I could by hand with no problems. You should be alright, Just keep watch on the filter for the 1st few times you use the tractor.
   / Now Hydro Filter Not On Tight Enough! #8
The question is do want to take it off with hammer and punch. Like the guys said. Hand tight.Maybe little bit more. Heavey Equipment Operator.
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2004 Ditch Witch RT70M Ride On Trencher (A50860)
2004 Ditch Witch...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A48081)
2013 International...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
