NOW THIS IS A BRUSH CUTTER
Status
Not open for further replies.
   / NOW THIS IS A BRUSH CUTTER #11
Those are really popular here in Vermont too.. The local state garage has a big New Holland, and a few of the new Landinis with the side mount mowers.. They do make a big mess, but thinking back to how they used to do it, with a sickle bar... much better visibility now.
   / NOW THIS IS A BRUSH CUTTER #12
I don't know what is so special about that brush cutter to have your panties up in a bunch, you should see the teeth on my mother in law . . . when she gets going she should take down a redwood /forums/images/graemlins/blush.gif
   / NOW THIS IS A BRUSH CUTTER #13
As others have said, that tractor is heavy and has rear wheel weights. I also suspect the rear tires are filled probably to the tune of 1000# each.
Also there appears to be a counterweight located beneath the tractor as well as a rear oil tank that serves as a counterweight. I have attached a photoshop enchanced picture of what apppears to be the center counterweight. Alamo sells "small" versions of this type of boom cutter that will fit on larger compacts for about $10-$12k.
Andy
   / NOW THIS IS A BRUSH CUTTER #14
I'd like to have his job. Talk about great seat time.
   / NOW THIS IS A BRUSH CUTTER #15
Status
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
(3) DRILLS (A58374)
(3) DRILLS (A58374)
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
1324 (A58374)
1324 (A58374)
