I'm not so sure a power shuttle tranny would be as good for snow thrower ops, although I'm sure it would get the job done.
The problem, as I see it, is that you want the engine to be at PTO speed to run the thrower properly, and engine speed is what varies ground speed with a shuttle tranny. That means when you want to slow down, or speed up, for the conditions/depth of snow, you have to change gears, push in the clutch, or accept that the thrower is at the wrong speed and may not throw the snow far enough. With an HST transmission you set the RPM to PTO speed, and move the pedals to vary speed within the range selected...very easy to do and the thrower is running at the proper speed the whole time.
Keep in mind I don't own anything with an HST transmission right now, so I'm not overly biased in their favor. I love the power shuttle in my backhoe, and I know I can do delicate, accurate, fast work with it, but it would definitely be a touch easier/faster if it were an HST system.
