O my, I am comfused
   / O my, I am comfused #201
The grousers on the Dozer were not just worn down to nothing, they were "gone". Or as near as I can tell from the crummy video resolution.
Coming from farm country and not construction country, all of the dozers I've ever been around were old machines that a farmer had picked up cheap. All the tracks were smooth. I didn't even realize they were supposed to have grousers! :laughing:
So I looked at new dozers on the internet after reading your comment and Yea, I can see how a track full of metal bars (basically the metal track version of R1 tires) would be superior to R1 tires for pulling in any surface soft enough for them to dig in.
This is a perfect example of needing to be specific on these threads, otherwise people become poorly educated. There are lots of different tracks out there - rubber, metal, smooth or with traction aids, different styles of traction aids. For this reason, a general statement like "tracks will out pull tires" can lead someone down the wrong path if they buy into it.
What are the critical details you need?
That being said tho the sub compact machines are just starting to look over priced to me. That doesnt mean i wont buy one, but i am exploring compact machines now. As far as putting the machine in my grass i also have that in mind. I dont want to ruin my lawn, so i will be cautious moving forward.
I dont have any real seat time in tractors, i know this. But common sense tells my if a subcompact costs 16g and i can get a compact for 20g and can put alot more implememts on the compact well then i am going to look inot that.
I like the john deere 1025r and the price. But i cannot put a real grapple on it, (weight) i canot put a post whole digger on it(john deere does not recommend it. If a put a thumb style grapple(smallest version) or a regular grapple on it i need to get some type of 3rd valve on it, then i cannot buy a rear back ho if i want in the future. I also cannot put a wood splitter on it. Im gonna keep whatever machine i buy forever. As life moves forward and lets say new thing arise i already shot myself in the foot and the machine is not readynfor the futurE.
I have stated that i want to move log length firewood around. Well in order to get a grapple attachemnt i aleady am limiting my lift capacity on a sub compact. I also stated i want a log splitter attachemnt. and a mower. These 3 reason are why i am buying a tractor for the present time.
The one machine i like is am looking at is a massey furguson (1726e\1734e)but these do not allow a mmm deck. I have to get a rear mower which im not sure if i will like. Also a john deere looking at jd 2025r and 2032. Yes the bigger hp machine have the dpf, but thats 1,000 hrs away and i wont hit that until 10 years from now.
I have found some superior deals on manuals. Which everyone on this thread has told me to get a hydro. But I don't see the huge negative as others. That said i am going to test drive some manuals on monday and use the loader at the same time.
   / O my, I am comfused #203
I talked with my dealer yesterday about the difference in price between a 1025R and the 3032R and was told about $7500 roughly. Helping a friend of mine choose what to get, not for me. When you say you want to move full length logs, that makes a huge difference in what is needed. Just my thought but WHY? It would seem cutting down the logs to fit the smaller machine would save thousands of dollars and be easier to maneuver in tight quarters. I suspect you are setting up parameters and or guide lines that don't work well together, heavy fel work and lawn work require different machine designs.
After about 50 years using tractors and equipment I think I have a handle on what works best for me.
I use the x749 mower without fel or extra weight for mowing and maintaining my lawn areas. I want this to be as light as possible so it doesn't track up the lawn. I have attachments for box blade, pine straw rake, collection system, drop seeder, broadcast spreader, land scape rake, rear bade, chipper and land plane grader, This allows me to keep my lawn and a few customers lawns in good shape. Only on rare occasions do I need to put a larger machine on these lawns.
The compact backhoe and compact tractors are used to build these landscapes initially and are not needed much to maintain the finished lawns. To safely and effectively use the fel and pull heavy box blades requires these tractors to weigh too much for routine mowing of a manicured lawn. Removing the fel might be easy but removing rear tire weights or fluid isn't practical. Using a weighted machine on routine lawn mowing will cause the lawn to suffer.
My suggestion is to have a separate light weight mower for the lawn and a few attachments for maintaining the lawn. A separate tractor with fel could be ballasted properly for the heavier work. This could be new or used and kept off the lawn for the most part.
Well to pic up those logs you need a grapple. The logs can be cut down obviosuly. But just putting a grapple in a sub compact pretty much just make the loader useless from what inhave been reading. I have seen plenty of videos of compacts tractors mowing lawns perfectly. Maybe not when the ground is wet, but ill wait for it to dry then.
   / O my, I am comfused #205
Nikko, if you are going to be at a massey dealer this week . . Be sure to try out a gc1715. You can have a choice of 4 different mower decks. You can add a quick attach feature to the front end loader thru
MyTractorTools.com
and that same business sells 4 different grapple versions that can use the same quick attach. They also offer front and rear forks again using the quick attach feature. I got a set of forks for my gc1715 from them . . . And their unique advantage is they can be used on the front end loader AND they can be usrd on the 3 pt as well.
Thru many vendors you can add a rear tiller or bush hogg or rear blade or blower.
   / O my, I am comfused #206
Nikko,
As I mentioned in a post quite awhile ago on this thread . . I put just under 500 pounds of log in my gc1715 bucket and when I get my mini grapple I'll be able to carry a 600 pound log.
   / O my, I am comfused #207
What are the critical details you need? ...I have stated that i want to move log length firewood around. Well in order to get a grapple attachemnt i aleady am limiting my lift capacity on a sub compact. I also stated i want a log splitter attachment. and a mower. These 3 reason are why i am buying a tractor for the present time.
Log length firewood could mean 300 pounds or 3000 pounds - each having very different machine requirements. I have a friend that get's log length logs delivered but he doesn't get to pick the size of the logs and some have been 3+ foot diameter. Specifically, how much weight do you want to be able to lift from the ground, off a truck or to a certain height?
Grapples tend to be heavy and with the limited lift capacity of a SCUT the extra weight of the grapple will severely reduce your lift capacity. If the tractor is rated at 1000 pounds at the pins and has 5 ft loader arms and center of your load is 2 ft past the loader arms you only have about 700 pounds of lift at the load center. If you now replace your bucket with a grapple that weighs 200 pounds more, you have 500 pounds of lift. And it would have to be a very light grapple to only weigh 200 pounds more than your bucket. With the wrong SCUT grapple combo you could end up with little useable lift.
Others have discussed the hydraulic flow requirements for a splitter. So I wont rehash.
Mowing - Again - not a fan of mowing with a loader machine. And think you should have two separate machines. I understand that you don't want to maintain a separate machine. Keep in mind, that you will spend more time taking a mowing deck on and off of a multipurpose tractor than you will maintaining another engine. And for the price of a SCUT mowing deck you might be able to get a decent machine for your lawn. However, if you want only one machine, you are not necessarily locked into a SCUT. large turf tires on a large CUT will make it float just as well as a SCUT. Just look at the utility tractors golf courses use.
That being said tho the sub compact machines are just starting to look over priced to me. That doesnt mean i wont buy one, but i am exploring compact machines now. As far as putting the machine in my grass i also have that in mind. I dont want to ruin my lawn, so i will be cautious moving forward. [/QOUTE]
Again inexpensive riding mower will do less damage to your lawn than a SCUT. You may want to get one of these and save money for a CUT.
QUOTE] I dont have any real seat time in tractors, i know this. But common sense tells my if a subcompact costs 16g and i can get a compact for 20g and can put alot more implememts on the compact well then i am going to look inot that.
CUTS are the easiest to find implements for. Standard Cat 1 implements are plentiful and with more power you have more options. SCUTs often take Cat 0 implements which are harder to find and aren't always less expensive.
I'm glad you're thinking ahead. The vast majority of people who trade in / sell their first tractor do it to get a bigger one. I have the biggest tractor I can trailer without buying a bigger trailer and truck. However, if I had a bigger trailer and truck I would have gone even bigger. It would be a little easier to do some things that I do. I don't think any SCUT or even small CUT makes a great post hole digging tractor - 3pt lift height and force are important for this. One of the mistakes I made was not getting all the hydraulics I could have initially. I opted for 1 rear remote when 2 were available. Well now I wish I had 3! Once you have the tractor, you will find even more things to do with it so I like the way you are thinking about hydraulics and future needs.
For the price of a good deck for a tractor, you can get a dedicated mower. If going 26+ hp, see if there are any leftovers with interim Tier IV emissions. They should be less expensive and need less maintenance than the Tier IV tractors.
The clouds open, a ray of light shines through and the choir sings! HST is nice, very nice. But I'm a huge gear fan because the value proposition is really good. Don't be scared of gear tractors. They are harder to get good with but once you do, the HST advantage is minimized. I found a 45hp left over interim Tier IV tractor with a hydraulic shuttle - so no clutching to change directions - for $19,600 (with loader & rear remote). Compare that to the HST tractors you are looking at. For a little more perspective, my breakout force is near 4000 pounds and full height lift near 3000 pounds. And this larger tractor is not worse on the lawn than my 19 hp was because the tires are proportionately bigger - both are too heavy to mow with IMHO. That is why I have a separate mower.
this is just an example of the value with gear, I know you're not looking at 45 hp tractors... yet ;)
Definitely test drive some gear units and see what you think. They're not for everyone.
   / O my, I am comfused #208
With the assistance from your chainsaw a BX can unload a 30" log. A 30 inch diameter 8 foot long log can weigh thousands of pounds. A grapple does slightly reduce the lift capacity over SSQA forks, but it is well worth the compromise.
   / O my, I am comfused #209
Let me break this response down. A grapple is a handy tool to have but cutting up enough logs to heat a suburban home I question the need for it. As for whether it will work on a sub compact I did not suggest it and don't recommend it either. Compact tractors without ballast and turf tires can do a decent job of mowing. Compact tractors with ballast can mow a lawn too, but repeated use over the years and the lawn will suffer. If you have many plantings or trees to mow around a zero turn or 4 wheel steer mower will be easier to maneuver with and cause less compaction and ruts over the years. My own preference is for the 4 wheel steer and the hydraulic front wheel 4x4, I haven' experienced any scuffing on my lawn with this set up.
A lot would depend on the size and weight of the logs you are dealing with. A small sub compact or small compact can pick up a decent sized log enough to cut it in two pieces. Obviously a larger tractor can pick up a larger log, so what are you dealing with? This is really about compromises between your uses and you would have to decide which is more important to you.
A 1734 e massey which has plenty of power. Manual transmission doesn not hace a mmm deck i have to get a rear. Which im not sure is going to be good as i have many trees. So im thinking of cutting down some tress lol. Im also thinking about the jd 2032 but the warranty is less but has a hydro tranny. Both machine are in the 20g range. Still more then i originnaly wanted to spend. But my original budget hinders me in the future.
Any compact tractors loader you guys know of the can take a mmm that are in the 20g rage?
Jenkin no one can predict the future of what new jobs may come up. But to amswer your question about the logs, when companies drops off logs im pretty their they are big. Like i said i can cut them down with my chainsaw but to make em more movable. I Don't buy log length now I buy em split already. But at more then half the price at log length. One part of my property is in a corner so im not worried about making a mess i can have them deliverd in the corner and do my work their. But when they deliver the logs its gonna a pile of them. I need something to pic them out of the pile(grapple hook) so i can cut and split. Then i can take my loader off put my mower on and cut some grass.
SUV (A59231)
SUV (A59231)
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2014 Yamaha YRDEX4 Electric Cart (A56859)
2014 Yamaha YRDEX4...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
