Odd Question - My freezer is sweating??? WTH?
   / Odd Question - My freezer is sweating??? WTH? #21
Could just be a simple as a leaky door seal that lets cold air seep through, that when it hits the humid room air condensenses it and drops the water out of it. Check the seals and push the door closed tight.
   / Odd Question - My freezer is sweating??? WTH? #22
Hopefully your issue is now resolved....but for reference, a DE-humidifier is nothing more than an air conditioner whose condensor coil is directly downstream from the evaporator. The evaporator draws the moisture out of the passing air, then the drier cooled air passes immediately over the condensor coil to re-heat the air so there is no temperature change within the space. The amount of heat extracted by the cooling will just be dumped right back in...with just a little added heat that is the result of the "heat of compression".
In theory, if you have an old 6,000 or 8,000 btu window a/c just sitting on the shelf collecting dust...(doesn't everybody??)... you can sit it over a basement drain and plug it in with the thermostat set to a low setting. The front will blow cold (of course) and the back will blow warm and the space temp should remain close to the same. Except with less moisture.
Yeah, it may freeze up.... but unplug it and let it defrost and do it again. Its just a suggestion if you HAVE a window unit laying there and don't want to spend the few bucks for a DE-humidifier that may not see a whole lot of use...
   / Odd Question - My freezer is sweating??? WTH? #23
It's not important whether the freezer has a heated door, or if the door seal has an issue. There would not be that much moisture condensing on it, unless the humidity is high.
The OP has said the basement is humid. Getting the humidity down to 50% or lower is the only thing I would be concerned about right now.
   / Odd Question - My freezer is sweating??? WTH? #24
Condensation is caused by the amount of water vapor that can be held in the air. Warmer air can hold more water, so when you lower the temperature in a warm area that has high humidity, the water vapor turns to liquid water. This is most common with a cold drink on a warm day. The air around the glass or can is cold enough to lower the temperature of the air right next to it enough to exceed what the air can hold
In the case of the freezer that is "sweating," the freezer is lowering the temperature of the air next to it in those areas that are wet. The freezer is poorly insulated in those spots and lowering the air temperature around it to the point of creating condensation.
Your options to stop this from happening are to fix or replace the freezer, relocate it to an area where the air temperature is controlled or reduce the amount of humidity in the air, or leaving it as is and dealing with the moisture. Lowing the level of the humidity is either going to be expensive or short term depending on the amount of water left in the area from the flooding. Did this ever happen before the flood?
Moving air is the best, most effective method for drying out wet areas. A cheap box fan is extremely effective at this and if it's just a short term fix, that's what I'd use.
Mold is easy to kill with household bleach. If you see any discoloration, or you just want to make sure none starts to form, spray with laundry bleach. If you have it already, the box stores sell a higher concentration of bleach that is designed for outdoor cleaning that works well. If it's really bad, I use swimming pool shock that I buy at Home Depot by the gallon. It is the strongest concentration of bleach that I'm aware of that you can buy. It will make your eyes water and you will smell it all through the house for at least a day. It will turn lumber that is black with mold back to looking brand new with a few application. I use a squirt bottle and just soak everything. This is something that is pretty common in bathroom remodels and it's proven to be a very cheap and effective way to deal with mold.
Good luck
Eddie
   / Odd Question - My freezer is sweating??? WTH? #25
Mold is killed by contact with household bleach. But is only effective on non-porous surfaces
If the surface is porous, like wood, or cinder block, bleach is only effective on the surface mold. This is because the VOC's that kill the mold mostly evaporate before they can soak into the pours. What is left after the VOC's evaporate is mostly water. Which can help propagate the next batch of mold, requiring future treatments.
Bleach is also toxic, and smells bad.
It's better to use a product like Moldex. It's very effective, has no offensive odor, and inhibits the return of future mold.
Last night I put some of those "Damp-Rid" things that pull moisture out of the air and by morning it was already better.
I just plugged in a 70 pint per day de-humidifier that is rated for 3x the space that I have in my basement.
Once again, TBN saves the day!
Thank you one and all!
Be well,
David
For the record, my favorite response was the one with Beer... :drink:
:D
I set it to 30% and after 15 minutes it is reading 76%.
Yup, I needed it.
Thanks guys!
David
   / Odd Question - My freezer is sweating??? WTH? #28
Use any fans you have to move air around down there, that will help the dehumidifier get it all.
It could take a while to dry it out, depending on the size of the basement.
Ray,
1400 square feet. I set up a couple fans also.
I just came in from mowing and had to empty the 2 gallon bucket.
I will try to set up the hose tomorrow...
Thanks again, Be well,
David
   / Odd Question - My freezer is sweating??? WTH? #30
Two gallons in 6 hours?
I'd set up the hose tonight!
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
2012 International ProStar T/A Day Cab Truck Tractor (A53422)
2012 International...
