CobyRupert
Super Member
It's not important whether the freezer has a heated door, or if the door seal has an issue. There would not be that much moisture condensing on it, unless the humidity is high.
The OP has said the basement is humid. Getting the humidity down to 50% or lower is the only thing I would be concerned about right now.
:banghead: Ughh. You may get the humidity down to where leaking cold air escaping doesn't condense water out of the room air. But your wasting so much energy running a leaking fridge and a dehumidifier, when the problem may just be the fact air can move between the cold inside and the humid outside. Seals.
