Offsetting Scraper Blade
/ Offsetting Scraper Blade #1
94BULLITT
Super Member
USA
yes
What is the best way to offset a scraper blade, with a screw jack, a sliding linkage? I know the screw jack is slower but it is infinitely adjustable. I don't want a hydraulic cylinder.
/ Offsetting Scraper Blade #2
sliding linkage.
How could you possible not want hydraulic offset? Perhaps you mean your tractor doesn't have the capability to use hydraulic offset?
/ Offsetting Scraper Blade #3
Are you asking because you are considering a purchase???
Or are you asking because you want to modify an existing blade??
The slider seems easier and simpler to do if making a modification. But off-setting the tongue part is how most of the heavier blades do it. Not sure how you would use the jack screw??
/ Offsetting Scraper Blade #4
This is how mine offsets. Move two bolts on top and three plow bolts on the bottom.
I currently have a blade that has a screw jack. I may purchase a blade that has a sliding linkage. I am going to sell my old blade and I don't know what to keep.
/ Offsetting Scraper Blade #6
How is the jackscrew set-up for the offset?? got any pics??
Personally though, I havent seen a slider that would handle what your 4240 could dish out. Short of spending some big $$$. Those "common" ones like everythingattachments sells, I dont like. I had one and saw the flexing just under light use with my much lighter L3400. I got rid of that blade before I destroyed it. But it was just one of them good deals on c-list that I grabbed it for $80 and had no trouble selling it for $300. It was a 7'er too.
I would not put one of those slider blades on it, they belong a B or BX. I am looking at a woods HBL-84. The offset is controlled by sliding linkage. Here is a link to picture (see page 4) look at the left side of the blade. Here my current blade it is a tuffline GB4-72.
/ Offsetting Scraper Blade #8
I see now. A sliding linkage and not one like this Tractor Slider Scrape Blades | Free Shipping within 1,000 miles!
I like that tuffline blade:thumbsup: It looks stout.
I really dont think it will make any practical difference. They would both be strong. The slider is quicker but fewer adjustemts.
Actually, if you got the slider and decided you didnt like it, you can just buy a turnbuckle and convert back without spending a fortune.
Are you wanting to got bigger?? 6' up to a 7'??
Yeah 6 to a 7 so it will cut the tracks out angled. I got the tuffline for the Bobcat now I need to upgrade. I only offset the tuffline 1 time to see how far it would go.
I got the blade. It is barely used and always kept inside. I feel I got it at a good deal. Now I need to sell the tuffline.
/ Offsetting Scraper Blade #11
Nice blade. But I think you owe us some better pics this morning when the sun comes up:D
/ Offsetting Scraper Blade #12
....and some action shots :thumbsup:
Congrats on the new tool!
Here are some better pictures but it is not on the tractor. I am fixing up a old storage shed and I am going to move it. I may use the new blade to level the spot and I will get some action shots then.
Here are some pictures of the old blade. I always thought it was a copy of a woods. They both are made very similar but everything is different.
/ Offsetting Scraper Blade #14
Wow. Those are really similar.
I wonder if Woods was making blades for Tufline under contract?
Either way, congratulations on the new Woods blade - very nice.
/ Offsetting Scraper Blade #15
I'd say that both of them blades came out of the same shop:rolleyes:
At a glance they look like twins but they are completely different. The tuffline has pins that are cat 1 and cat 2, the woods has cat 1 pins all the way through and bushings for cat 2. The woods is qh compatible the tuffline is not but it is just a extra toplink pin hole. The top of the moldboard on the tuffline is flat and you could sit on it the woods on a angle. The woods moldboard is only braced with 1 piece of angle the tuffline has 2. The park stands are in different locations and the woods is round and the tuffline is square. I think the woods blade is longer. The piece in the back where the circular piece attaches with 4 bolts on the tuffline is made out of 3 pieces of metal welded together the woods is one piece that was made in a break. The upright supports for the toplink are different. The top link hook ups are different. The piece coming down from the toplink the goes to the 4x4 piece of metal is straight on the woods and curved on the tuffline. The tuffline has a lift hook. Woods, tuffline, land pride, rhino, and bush hog all have blades that look like this. I guess they all copy each other.
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
Unused 2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
Unused 2021...
2007 KENWORTH W900 (A67714)
2007 KENWORTH W900...
