Oh no!!! Flat tire already!!!
   / Oh no!!! Flat tire already!!!
It sounds appealing. You get a virtually indestructible tire with extremely good ballast weight.:D But I don't know if it's worth it at that price. My tires are 16.9-30. You're probably talking about at least$1100 per tire!:eek: $2200 would buy one serious implement. Also, you don't necessarily have to replace the tire when you get a flat. Like I said, the total cost to me was $73 for tube replacement and labor. If I were using a wheeled TLB on a contruction site with nails, metal, and all sorts of dangerous sharp debris I could see it. But on a tractor mostly in the field, I doubt it. You'd have to be really prone to flats for it to be worth it. Still, if I could find someone to do it, and do it right, for a few hundred dollars I would have it done.
   / Oh no!!! Flat tire already!!! #32
You could probably get the tires retreaded when they get low on tread. This my be a way to make this a good way to go.
   / Oh no!!! Flat tire already!!! #33
Taiser said:
$980.00 per tire!!??!!?? :eek:
Yup, it is expensive. I shyed away from the foam on my first set of tires, but after dealing with flats for a few years the price started to sound more reasonable. Bear in mind that foam is priced by the pound - my little tires were filled for something like $75 each. I think I paid $400 for new tires, foam filled.
It was enough $$$ that I didn't want to fill up worn down tires, so I dealt with a few more flats until the tread was gone enough that I could justify new tires. Foam filled. :)
   / Oh no!!! Flat tire already!!! #34
You will never be able to retread foam filled tires, just not an option.
   / Oh no!!! Flat tire already!!! #35
Glowplug, apr. '05 my tires were foam filled w/superflex
7X16 front ag.-- $104.50 ea.
12.4X24 rear ag. $360.00 ea.
535 lbs. were added to each rear tire. don't recall how much weight was added to the front tires. cost is by the lb. so ya can go figure.
Pat Payne Distributors
Brooks, Ky.40109
502 955 6225 fax 502 955 6776
if ye do this, don't ever plan on having another flat or even consider
rolling the tire off the rim with a load in the loader!
your tires will cost more cause they are bigger.
mind ya this is with a senior citizen discount!!!!!! $15.00 woopidy-doo!!!
also you might be surprized how long ag tires will last on a tractor.
yeah wifey thought it was a little steep but I don't fool with flats any more.
haven't had any problems-----yet. 950 hrs. L3130GST 723 loader woods 7500
this place is about 1/2 mi. from the CSX train derailment 2 wks. ago in Brooks
CharlieKTractor, Thanks!!! Now that's a "reasonable" price to pay. I'll have to look into it. I think Brooks is a good bit west of me. If it's too far I may be able to find someone closer who could do it as well.
P.S. I just looked it up on Mapquest. Brooks is just outside of Louisville, immediately south. That is not impossible for me to get there. I'll have to think about it.
   / Oh no!!! Flat tire already!!! #37
Unless your back is made of steel, DON'T get the tires filled with foam.
They take all the give out. You can use SLIME or BERRYMAN and forget
about flats. Also foam is crazy in price and adds lots of weight which can
sometimes be good, and sometimes a problem.
   / Oh no!!! Flat tire already!!! #38
Holy thread resurections Batman!!! :D
Welcome to the forum!
I disagree, sure it's stiffer, but how much give does my tractor have anyways with no suspension? I'm not driving down the highway and it's rare for me to even take the thing out of low gear.
I'm foaming the fronts, just cause I've had two flats already and foam don't leak. The next time I have to take the tire off it will be bald! Weight is usually a good thing for my (any) tractor! :)
   / Oh no!!! Flat tire already!!! #39
I have been struggling with flat tires on my BX-23 for 3 years. A total of 9 flats and 2 replaced rear tires. One of my fronts now needs to be replaced. I'm sick of spending money on repairs/tires but I cannot see spending the $485 on foam that I was quoted today. I priced a complete set of Bar tires AND wheels for the BX today at $350. The Real Issue here (as I see it) is the Terrible Quality of the BX 23 Tires. I've seen thicker rubber on a bicycle! I get flats just driving across the front lawn. Sticks no bigger than a pencil have done me in 3 times. I wish I could find a nice 6 or 8 ply tire to fit a BX-23, but so far all I can find are tires for a QUAD. Any help out there? Does the BX-24 have real tires on it? Can I swap them to the 23? Help!! I'm drowning in Green slim and fix-a-flat!
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2018 Deere 323E (A53317)
2018 Deere 323E...
Enmark Z Spray (A53316)
Enmark Z Spray...
