Oil & Fuel Oil capacity 2130 different
   / Oil capacity 2130 different #1
Ausmac
Proserpine QLD
Massey Ferguson 188, JD 2130, Fiat 650
Hi all. Just changed a lift pump out on the 2130 and dropped the oil as it had been taking on diesel. The book says 9 quarts oil capacity. Can anyone tell me why mine only took 6.5 quarts? I did not change the filter and verified the dipstick is correct AT21534 stamped on. Also verified the oil pressure warning light works and was not lit when running.
   / Oil capacity 2130 different #2
Maybe it has 2 oil drain plugs......:confused3:
Just went and had another look. Definitely one sump plug.
   / Oil capacity 2130 different #4
Generally the oil capacity is given for a completely empty engine - like new or freshly overhauled. That could account for some of the difference. Not replacing the oil filter could account for a bit more.
Thanks. I was wondering if the sump pan maybe had a lot of sludge on it displacing the oil and therefore taking less?
   / Oil capacity 2130 different #6
Trying to determine if there is sludge in the oil pan may be worthwhile, for peace of mind if nothing else.
The part drawing looks to be compartmentalized a bit, and I see that the pan gasket is still available.. part # R49515, if you went ahead and removed the oil pan.. sludge won't be helping the oil pump in that pan if very bad.
   / Oil capacity 2130 different #7
JD2520 RC utilizes same engine oil pan & dipstick & it lists engine oil cap @ 7qts
   / Oil capacity 2130 different #8
The oil filter will be some of the oil not accounted for. Does your tractor have an engine oil cooler? That could also account for some of the oil.
7 quarts Jim? Maybe I am wrong then. Checked a few sites yesterday and they all said 9 (or 8.5 litres). Zebra I have a section on the radiator which I thought was trans cooler? The sump pan is a simple drop off job right? New gasket and away I go?
   / Oil capacity 2130 different #10
JD parts shows an adapter at the oil filter for an oil cooler. I've never actually seen one. The cooler to right of the radiator is a transmission cooler.
I would not drop the oil pan. It is simple unbolt and new gasket.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
Giyi Log Splitter (A53316)
Giyi Log Splitter...
2008 Dodge Avenger Sedan (A55758)
2008 Dodge Avenger...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
