Oil Consumption BX2200
   / Oil Consumption BX2200 #1
discus
For those of you with a BX2200, what kind of oil consumption rate are you seeing? It doesn't have to be scientific, just a rough figure from the dipstick is fine.
   / Oil Consumption BX2200 #2
I have 80 hours on my 2200 and the only oil I have added was at the 50 hour change. I am now running Amsoil.....
No problems here!
   / Oil Consumption BX2200 #3
I have roughly 138 hours on mine and have never noticed any oil consumption, like Sandy C The only time I have ever put oil in it is when i change oil.
Always stays the same on the dipstick. /forums/images/graemlins/grin.gif
   / Oil Consumption BX2200 #4
Same here, I use no oil in my BX, at least the level does not change on the dipstick. Of course, I change the oil and filter very 50 hours.
Will
   / Oil Consumption BX2200 #5
My BX2200 has about 140 hours. I see about 1/4 qt consumption in about 30 hours.
Jon
   / Oil Consumption BX2200 #6
I have about 220 hours on my BX22 and have never had to top off the oil and I check reguarly. I have added a little UDT a couple of times. I have changed oil and filter 3 time and switched to Mobile 1 the last time.
   / Oil Consumption BX2200 #8
Never had to add oil. I did change it at about 50, 125 and 200. The one at about 200 was because I switched to Mobile 1 for the winter to help it start on colder days.
I have had to top up UDT a couple of times. I had to replace the filter and UDT at about 10 hours because my PTO shaft on the MMM came off and punched a hole in the filter. Now the mower goes on in the spring and stays on all summer/fall.
   / Oil Consumption BX2200 #9
No noticeable oil consumption
Thanks for all the replies. I'm just trying to figure out if mine is inline with what others are seeing, and it appears to be. I too changed the oil at 35, 70 and 100 hours. At the 100 hour change I went to Mobil 1. Haven't added any UDT yet, but it was changed at 35 hours too.
2018 Nissan Murano SUV (A50324)
2018 Nissan Murano...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
