Oil filter for 4720ch
   / Oil filter for 4720ch #31
Bob that's great that you took the time to do this. Looks like the filter on the left has the media pleats more closely spaced. Not that you need to do this, but if you were to remove the media and stretch it out and measure it, I wonder if the number of square inches of media on each would be similar. I guess I am saying a larger canister may not mean more filtration necessarily.
I suspect a person could use a variety of filters and get the same filtration, so long as the specs were close. Often, as defined a few posts above, there will be differences in the bypass pressure and perhaps allowable full flow rate. I'm not sure how important those things are if it bypasses at 11psi or 15psi, not sure if that matters much. Having said that, as a dealer we just suggest the OEM filter in all cases, but I do acknowledge that the OEMs don't make their own filters and surely there are as good or better filters available aftermarket so long as some knowledgeable person has spec'd it correctly. The fact that Wix apparently has a listing now is encouraging. There is a Wix dealer in every town, not the case with a Branson dealer.
I'm mostly concerned myself with air filtration. If you install an air filter that does not seal well, you may not know it. Whereas an oil filter will make a leaky mess, an air filter will just allow dirt to slowly be ingested. Do that for just a while in a dusty environment and you need an engine. The piston rings take that dust and rub it up and down like sand paper on the cylinder walls.
I do think the HST filter might be a little more complicated than the engine oil filter. I'd be less likely to just use something that fits. I'd want to be real sure of any crossover on that.
   / Oil filter for 4720ch #32
Dave I like your Amazon idea. Just bought the air filter set from Amazon. No Dealer where I live, and the dealer's part's counter gave me the wrong size a couple months ago when I was back where I bought the tractor. Ron
   / Oil filter for 4720ch #33
Hi Dave.
Yes I thought it was important to change the engine oil filter until I could get the stock one in hand so it was only done in a pinch. I agree that it would not be wise to do the same for the hydraulic or air.
Hope you and all the gang are well.
   / Oil filter for 4720ch #34
I want to inform you all that if you have existing warranty on your engine and do not use the Branson oil filter and that engine takes a dump you may be on your own for the cost of the new engine. I guarantee that Branson will see the aftermarket filter and red flags Will Go up immediately. I understand some of you that have no Branson dealer close to you but it's not hard to call/email a dealer and get a filter sent to you it might be worth it.
   / Oil filter for 4720ch #35
Thank you and duly noted, in fact I considered this before the changing the filter.
BTW, it would be pretty petty and bush league for a corporation the size of Branson to invoke something like this as an opportunity to not stand behind their product wouldn't it?
At any rate I totally trust my dealership to advocate in good faith as most of your customers also trust your sterling reputation.
Thanks again Mr Bitz.
   / Oil filter for 4720ch #36
I agree but with any manufacturers or insurance companies they seem to look for little cracks to escape on. However I have yet to find Branson looking for ways out. They have been great.
   / Oil filter for 4720ch #37
Not to argue with Mr. Bitz whom I know and respect, but let me state my opinion.
There are laws regulating how warranty coverage works, and that is a good thing. You can read the Moss- Magnuson Act. It prohibits a company from requiring a customer use their filter, unless such filter is provided at no charge. A brand can however deny coverage if the wrong or inadequate filter is used and in doing so caused the damage. Just common sense. It is simple enough and a good practice to use the factory filters.
For example, if you use a Wix oil filter that is dead bang on in specs and the engine takes a dump, there may be a slight delay as Branson would want to verify that this non OEM filter is fine and did not cause a problem. But lets say you installed a Wix (or any brand) air filter and the radial seal was 1/4" diameter larger than the factory seal on this filter. You would get dirt in the engine and that dusted engine would not be covered. Makes sense that if a non Branson part actually damages an engine, that Branson would not have to pay for that error.
Is it better to use OEM filters? Probably for most people. Is it mandatory or should we be scared to use another good quality filter? No, just make sure it is of proper specs and quality.
   / Oil filter for 4720ch #38
Well said Dave. I agree 100%. I see no argument here.
   / Oil filter for 4720ch #39
The Magnuson-Moss Warranty Act (P.L. 93-637) (United States federal law 15 U.S.C. § 2301 et seq.) effectively prevents that from happening.
That is very encouraging - it is VITAL for their reputation!!!!
   / Oil filter for 4720ch #40
Here is a maybe little helpful info on a filter some Branson owners use. A Branson EA00001160B vs a NAPA 1347.
Filter media for Branson was 2" X 97" = 194 sq inches
Filter media for Napa was 3.75" X 61" = 228 3/4 sq inches
Now I'm not a filter expert nor do I really know anything about the, other than they filter oil but here is my observation on what I seen and you can judge by the pictures below as much as you can tell by them.
The media seemed pretty much the same maybe just a little thicker in the Napa filter. The spring in both seem to take about the same amount of force to compress. Both canisters along with the ends were very close to the same thickness and quality. As far as the rubber valve I guessing is part of the bypass the Napa one was what seem to me as a better constructed. The only other thing is the Napa had another round thing with a spring and rubber ring as seen in the picture and I have no idea what it is. Maybe some one with better knowledge can shed light on it.
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
Utility Trailer (A52377)
Utility Trailer...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
