Oil Filter number for Kohler 23hp Command?
   / Oil Filter number for Kohler 23hp Command? #1
Sigma
I plan on doing my first oil change on my ZF-50 soon. It has about 11 hours on it now.
I know its a spin on filter, but does anyone know a brand name or part number so I can pick up the filter with the oil somewhere other than the Cub dealer? I bought the mower from a dealer about an hour away, so its not worth driving there for oil and filter.
Thanks,
Greg
Thanks,
Greg
   / Oil Filter number for Kohler 23hp Command? #3
Depending on how much room you have, you can run right up to a long motorcraft FL400A or equiv. You can x-ref the CC filter thru www.wixfilters.com, fram, etc..
Joel
   / Oil Filter number for Kohler 23hp Command? #4
Joel
Just found in the manual, of course they only recommend using Kohler brand filters.
For my CV23, the original filter is : 12 050 01.
While home for lunch break, I read the number on the filter and noticed the oil drain tube just reaches the edge of the frame and does hang down over and is therefore higher than the point exiting the engine. Seems like there should be a hole in the frame to drop the drain hose down through. Maybe there is and I just haven't found it yet.
   / Oil Filter number for Kohler 23hp Command? #7
I've heard several people tell me that it is not a good idea to put automotive filters on any small engine since supposedly the are very different inside even if externally they look the same. Is that the consensus here as well?
   / Oil Filter number for Kohler 23hp Command? #8
   / Oil Filter number for Kohler 23hp Command? #9
The Wix 51056 is their cross for the Kohler 12 050 01. It's not an "automotive" filter in that it seems to be designed specifically for this application. The specs on the Wix look better to me than the Kohler OEM item.
   / Oil Filter number for Kohler 23hp Command? #10
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1604 (A57192)
1604 (A57192)
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
