oil pan drain bolt
   / oil pan drain bolt #11
One other thing, I don't know about the CK series but my DK pan is aluminum. .
I hope it has a shield over the oil pan from whatever could hit it from below. I have run over T posts that I did not know where there when clearing brush. Backing up, they tend to lodge under the tractor and bend into a U. I am not a a fan of anything aluminum under a tractor.
   / oil pan drain bolt #12
Nope, it is aluminum. but I don't see how a steel oil pan would stop a T post either unless it was really thick. If you are going to run over T post' you need to build some shields.
   / oil pan drain bolt #13
Well I haven't had any trouble yet, but if you got "jiggy" with the wrench, you sure could.
that hard drain plug will win against that soft pan every time.
Sometimes I see where a soft pan has a steel insert for the drain plug.
IMHO.. the best bet would be a soft plug and harder pan ( or insert ).
If they set it up correctly so that it clamps a good oring or washer.. should be fine i guess.
   / oil pan drain bolt #14
yep.. most steel pans are sheet metal and thin.. a heavy cast pan like a structural member under a ford N MIGHT do ok...
   / oil pan drain bolt #15
Actually the best I could tell it did lodge on the steel pan and resulted in a good scrape but no real damage. Had I known the T posts were in the brush I would not have backed up. But you don't know what you don't know.
Does anyone know the torque rating on the oil pan bolts for a 2008 CK35? Better yet is there a place to look at the shop manual in cyberspace?
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
