Oil Pressure Problem?
   / Oil Pressure Problem? #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Learned people the Oil Pressure Warning Light on my TX1510 has started coming on at low revs just recently what would be your possible diagnosis......please not expensive!!!
   / Oil Pressure Problem? #2
The least expensive thing to do is remove the warning light sensor and put an oil pressure gauge in its place to see what's REALLY happening. You may just have a defective sensor. The gauge will tell you for sure whether the fix is expensive or cheap - it will not tell you the fix unless it is indeed just a failed sensor. It's a starting point.
Many thanks for your reply and my apologies for the delay in replying. Rather than spend cash we haven't got right now on a gauge as the tractor was due its annual oil/filter change I did that but also put a new connector on the sensor and touch wood the light no longer comes on at low revs but obviously time will tell.....
finally managed to check the oil pressure today with a pressure tester just now and its 'ranging' between 6.5 and 7 PSI......is that good bad or??
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2018 CATERPILLAR D6K2 XL CRAWLER DOZER (A60429)
2018 CATERPILLAR...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2014 International Derrick Digger Truck (A55973)
2014 International...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
