y
OK It is 2011, Who Makes the Best 3 PT Snowblower
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #1
cointoss
NorthWest Michigan-Eastern UP
Kubota L 47, Kubota B 3200, Kubota M6040, John Deere 5200
Who makes the best 3pt snowblower, 6ft to 7ft? Things have changed since the 80s when I bought a Lucknow. Now I need to think about replaceing it and I am looking for greaseable bearings and somewhat heavy duty for deep snows I have here in the snowbelt area of Michigan.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #2
Got to go beyond than decals and labels.
A ton of these are produced by the same company for the OEMs. I believe one Canadian outfit does a bunch of them, for example.
Not a snow blower guy, I'm a pusher, so no expertise. Just dig a little deeper than the surface, that's all I am saying.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #3
There is no simple answer - several brands are well-made but which one is best depends on your preferences (backup, draw forward, front mount with rear drive). If you've worn out a Lucknow, you might want to look at something heavy like Erskine or Pronovost. Which tractor are you planning to put it on?
I plan on useing it as a rear mount and back up blower. The pull type look very interesting and sure would save my neck from keeping turned around but I want to continue with a rear 3 pt back up blower. Incidently I plan on useing it on a Ford New Holland 3930 tractor with a factory cab.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #5
I have a small Pronovost and I'm very happy with it. I don't think I've read a negative comment about Pronovost.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #6
RAD Technologies makes the snowblowers for most of the OEM's. They are supposed to be really good machines in their own right. Pronovost is also supposed to be at the top of the heap and frankly after looking around their website at some of their top end models, I'd have to say that in my opinion, if money was no object I'd rather have a Pronovost than any other snowblower. The RAD units would be a close second, and an Erskine would be a close third.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #7
i use a 78 " norman made in Quebec canada.Good blower no complaints
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #8
I don't know who makes the blowers for Bobcat, but they are really well built units. Dealer said they were coming from somewhere in the Southern US.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #9
Anybody own a Woods 3 point blower? They are a well known brand for equipment Do they make a quality snowblower?
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #10
I use a BerVac 64" older model on my property and with a 2.5 mile driveway and over 22ft. of snow last year my blower REAllY earns its keep for sure.
My closest neighbor 3 miles away, is a widow and I help her out alot and she has a 73" Allied blower that also works well. I have put many hours on that blower with a hiccup also.
But at work we have a 8ft. dual auger Pronovost. it is quite expensive, but being a Gov't job money is no issue...lol. And if money is no issue when looking for a blower I would have to say they don't make them much better or onger ( or expensive) as The Pronovost.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #11
I have sold Woods blowers for the past 6 yrs. After receiving the Bobcat blowers this year...they are the only ones I will be stocking.
VERY well built.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #12
I own a 6' woods and love it.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #13
ERSKINE makes bobcat snow blowers. My 60" rear pull weighs 800lbs
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #14
I have the 66" Bobcat rear pusher and it is right around 700lbs. Thanks for the link to Erskine.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #15
I picked up a 51 inch Blizzard blower last year. I'm very satisfied with it. I think it's well made and at a reasonable price. I had my heat set on a Woods unit, but haven't ben dissapointed
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #16
Simplest way to decide that is to buy the most expensive one you can find. You get what you pay for, will cover you well 99% of the time.
Other than that, the answer to "The Best" is only in the eyes of the beholder based on their bang for their buck. You (the OP) have the best answer for "the most bang for your buck".
IMO :)
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #17
.........The pull type look very interesting and sure would save my neck from keeping turned around Incidently I plan on useing it on a Ford New Holland 3930 tractor with a factory cab.
Another rugged Canadian product is Normand. As posted above, TBN member ihuntbear has a back up style and dylan uses a New Holland. tractor with a pull-forward. Notice the cool drag blade for getting close. More pics of Dylan's rig here and here and here. This Normand page shows their inverted machines.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #18
I can't compare it to other brands, but I have the RAD blower sold with a Kubota sticker on it and have been very happy with it. It works as it should and with a few winters behind it hasn't required anything except lube and an occasional shear bolt.
I have decided to go with a RAD blower. Has most of the features I was looking for but I will have to add more outlets and a control for the hyd chute.
   / OK It is 2011, Who Makes the Best 3 PT Snowblower #20
Another brand is Loftness, very rugged. I've had mine for 2 years, and no complaints. Never even broke a shear bolt until last week. I was cleaning out the horse's paddock after we got 26" in the blizzard, and hit a 3" stump. It actually sheared off the stump before it got stuck between the auger and drive sprocket.
Skid steer attachment manufacturer Minnesota, Loftness forestry products MN
Dan
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A59228)
1994 Generac...
Westfield Conveyor (A61307)
Westfield Conveyor...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
