aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I think the time it takes to spontaneously combust depends on the moisture content and how its stacked (ie: how well it can breath).Eddie--If hay is going to spontaneously combust, it does it on a given number of days after baling. I can't remember the days but maybe it's 11. Others will know. There is also a specific temp to watch for but I can't remember that either. If no one knows, I'll get the answer. Hay will heat a little after it's baled but that's no big deal.
The way to take a temperature is with a long soil thermometer, probably 12" or so. These are inexpensive at a hardware store and will reach to the center of a bale.
If I was going to buy hay out of the field I would bring someone with you that knows hay. Make arrangements with the farmer, tell him that you are an honorable person and say you will show up BEFORE he starts baling. That is a test of character he will appreciate.
Hoses need mold free hay or can develop respiratory problems so the hay cannot be rained on and needs to be baled at the correct time. I don't know southern hay but northern timothy or alfalfa hay is green in color and smells good enough to eat.
Find a farmer with good ground that know show to fertilize it and has reliable hay equipment.
We moisture test all of our hay and if its over 20%(or thereabout), it doesn't leave the farm except as junk/mulch hay.
A moisture tester like ours runs $225 at Gemplers (Agratronix HT-PRO Hay Temperature and Moisture Testers | GEMPLER'S) but its well worth being able to tell a buyer "pick a bale and we can test the moisture content" if they are worried about the moisture content. It also makes it easier to have a go/no go moisture level for us when baling.
Fresh small squares should ALWAYS be stacked with the strings on the side. That way the stack of hay can breath and you dont get pockets of warm moist air trapped in the stack.
Aaron Z
