Disc Harrow old disc repair
   / old disc repair
The shaft is square (other than where is has been rounded by the discs after it seized up). It runs through a round pipe that is on the inside of the bearing. I am not sure if this is how the disc was made or not, though I have not seen wood bearings that are square on the inside. So far, I have not been able to remove the one bearing I have tried to remove. I have tried to pound out the pipe in the middle, but cannot get anything to move. Might have to resort to a cutting torch.
   / old disc repair #52
Agri Supply has lots of parts to help you out
   / old disc repair
Agi-Supply does not seem to have the outer part of the bearing that goes around the spool for a 1 1/8" shaft, and that is the size I am trying to find. I also am not sure if there may be another sort of bearing that would work. Just looking for some information and ideas from someone more experienced than I am, as this is the only disc I have tried to replace bearings on.
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A50854)
2022 ALLIANCE...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
