old plow cat 1 pins too short to work with cat 2 hitch
   / old plow cat 1 pins too short to work with cat 2 hitch #1
Lowcountry Rebel
Ravenel S.C.
TYM 603
I bought an old double bottom plow with welded on cat 1 pins, started to attach it today for the first time and the cat 1 pins are too short for my cat 2 hitch- the retaining hole is partially hidden inside the hitch ball and I can't get a pin through.
I have an assortment of both sizes and use the sleeves to adjust.
I know I can cut/weld- or drill out the hole, but do they make an adapter that will pin on the cat 1 pin and allow me to connect my cat 2 hitch?
   / old plow cat 1 pins too short to work with cat 2 hitch #2
From your description I think your going to have to cut those off and weld new pins on
   / old plow cat 1 pins too short to work with cat 2 hitch #3
Agreed. Get longer Cat 1 pins at your local tractor dealer and after removing the short ones - weld on the new longer ones.
   / old plow cat 1 pins too short to work with cat 2 hitch #4
Never seen one and image search didn't find any.
One could be made, bored out to 7/8", that would slide over and pin to the cat 1 pin and go in the cat 2 socket.
   / old plow cat 1 pins too short to work with cat 2 hitch #5
Again I would just cut or remove old pins and install cat 2
   / old plow cat 1 pins too short to work with cat 2 hitch #6
Weld on a longer cat2 to cat 1 reducing sleeve with a hole drilled in it for the pin. No hole necessary if using quick hitch of course.
OR
Not ideal, but use the way it is with a smaller diameter lynch pin or grade 8 bolt if there’s enough room.
OR
Good Idea- thanks
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2014 PETERBILT 388 (A58214)
2014 PETERBILT 388...
2019 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A55973)
2019 John Deere...
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56435)
2020 John Deere...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
