Older Deere electronic de-stroker question
/ Older Deere electronic de-stroker question #1
MMagis
Veteran Member
Guernsey Co. Ohio
Ford 3000, JD 2550
Was hoping someone might be familiar with the electronic de-stroking kit for older Deere tractors. In the process of changing out hydraulic pump and ran into a quick question. Question being, looking at the diagrams on Deere's site, it appears that if I remove the de-stroking kit, I can just plug the ports it hooks into. Is that correct? The electronic de-stroker wasn't working, and one of the ports (drain) in the new pump doesn't match the previous. Could probably use an adapter, but would rather just get rid of it. Thanks.
Edit: I wanted to clarify, the port that doesn’t match is in the “cover”, not the pump itself. According to the diagram, both of these ports are plugged without the de-stroker being present. Assuming I’m interpreting the diagram correctly.
/ Older Deere electronic de-stroker question #2
Yes you should be able to just plug port that electric destroking valve was in.
Thank you. I thought that was correct, just wanted to check with someone more knowledgeable than me.
/ Older Deere electronic de-stroker question #4
You're welcome
Jim
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
