?? on NH 3930 drawbars
   / ?? on NH 3930 drawbars #1
JDRandyC
I bought a used NH 3930. It is missing the drawbar but it has the drawbar hangar. I purchased a tandem axel landscape trailer that I want to hook up to the tractor and use to collect limbs/trees etc. to transport to a central burn pile. I have the following questions.
1. I found a swinging drawbar on ebay and my intentions are to attach a ball to the end of the drawbar/clevis. Is the hole in the end of the drawbar a standard 1" hole that will fit the pin on the ball?
2. I see my hangar has a pin at the forward position that I assume goes through either of the two holes on the front of the drawbar. There are also two smaller pins at the rear of the hangar and I am not sure what these are for. Can anyone help me out on this.
3. If you dont want the drawbar to swing, which I think is what I would need to do if I am pulling a trailer, how do you set all of this up?
thanks
   / ?? on NH 3930 drawbars #2
The large pin under the tractor goes through the drawbar to keep it attached to the tractor, the two small pins in the hanger towards the rear of the tractor keep it from swinging side to side. If I remember right on mine I think they are like 3/8" pins (I lost the originals over the years and dropped 3/8" bolts in their place.
If I think about it I will get a picture of my setup and post it for you.
CAT 336E (A58214)
CAT 336E (A58214)
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
Blast Off Hot Pressure Washer Trailer (A59228)
Blast Off Hot...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
UNUSED FUTURE FTH50-(50) SHEETS OF GALVALUME (A60432)
UNUSED FUTURE...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
