one bottom or two???
/ one bottom or two??? #1
brown1
Bronze Member
grass lake mi
bobcat ct235
happy friday everyone, i am in the market for a molbord style plow and was wondering what my tar tor would handle. i have a 35hp bobcat four wheel drive compact with loaded turf tires, my ground has been worked a couple of years ago and it is a sandy loamy mix. has anyone pulled a 2 bottom with a similar tractor? i assume i should have no problem with a 1? thanks in advance for any help!
/ one bottom or two??? #2
I have pulled a 2 bottom 16 with a ford jubilee. 35 hp and 2 wd, in red clay. I would say no problem at all with your soil and tractor.
/ one bottom or two??? #3
I think you'll have a fine time with a 2 bottom given your tractor. 4WD plus weight in the rears. You can always add weight to the front or a FEL which I think would make it work even better.
If you have a buddy with a plow you might borrow it just to test what we say. EverythingAttachment could probably tell you exactly what you can use if you call them.
/ one bottom or two??? #4
I have pulled our old 2/14 two bottom with a 8N,L3130 and my L4240..you should have no problem with your tractor unless its real wet.......
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2014 Chevrolet Silverado 1500 (A64047)
2014 Chevrolet...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
