Open Center vs Closed Center
   / Open Center vs Closed Center #21
Dudes, chill out. I never singled out anyone as a "knowitall". Go read this thread from the beginning. I was simply making a joke about the complexity because the OP didn't seem to know what he had. Then I was attacked and called stupid as you just did. I'm not the fairy or unicorn here.
It's clear on who are the ones that think they are knowitalls. They are the one that tell you they are.
And they're the ones that are one bad hair day from imploding. I don't know what "his" comments were about. :confused2:
I didn't came back to this forum to be ridiculed and attacked. I initially joined about the same time you did. Some health issues put me on the sidelines for quite some time and I couldn't find my login info. So here I am--Trying to get my post count back up like you guys. :laughing:
I’m glad you didn’t call it a thingamajigger. I’d have been really offended.
   / Open Center vs Closed Center #22
It's possible for a CC system to use a fixed displacement pump with an unloader valve.
Unloader is like a pressure relief that can divert full flow (gpm) vs using a variable-displacement pump.
There are industrial applications, but I've never seen such a setup on a tractor.
   / Open Center vs Closed Center #23
Nobody called you or anyone else stupid. If the trolling reference bothers you then then don't post stuff that makes you think the comment might be directed at you.
   / Open Center vs Closed Center #24
There are thousands of Ford 10, 30, and 40 series tractors as well as TW Series II tractors with those exact systems. Fixed displacement gear pumps with unload valves and closed center remote valving.
   / Open Center vs Closed Center #25
Thanks, Rick, for the follow up!
I suspected wider use than fixed installations but couldn't cite a one.
Manac Walking Floor Trailer (A50322)
Manac Walking...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
