Opinions about a utility grader attachment...
   / Opinions about a utility grader attachment...
Thanks Brian,
Your pictures show a thousand words. I noticed in one pic that the grader has quite a load of dirt inside the frame. That answers a question or two that I wondered about. I had originally thought that the grader would not move or hold that much dirt, but it looks like it will collect quite a lot between the framework. Thanks for the advise and pics.
   / Opinions about a utility grader attachment... #12
Dave, if my ground is very dry and I set the grader height to ground level and not let it dig in any lower, then that is when the dirt sort of just spoils over the blades and does not build up like it is in the picture. If you do get one of these blades, as I have said, be sure to get the right size for your tractor. If you get one that is too big or too heavy for your tractor, it will be a battle every time that you use it.
2012 FORD F250 (INOPERABLE) (A50854)
2012 FORD F250...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
DOOSAN G90 GENERATOR (A50854)
DOOSAN G90...
3 pt Aer-Way (A50514)
C13 MOTOR (A50854)
C13 MOTOR (A50854)
